RS HEATER TUBE BYPASS QUESTIONS
Ordered a RS heater bypass tube to put into my car. I noticed there was no cutout for the folllowing items:
1) Series Resistor for Engine Compartment Blower Motor
2) Temperature Sensor (in Blower Duct) for Engine Compartment Blower Motor
I have read other treads where people have made provisions to have them installed by cutting the slot with a Dremel
What will happen if i remove the above items?
I read somewhere that you need to add a resistor to simulate the resistance of the missing eng comp blower so your cabin fans will work properly. Why would you need to reinstall a sensor and resistor that are a part of the blower fan you have removed?
I don't have a technical response, but I did what most people do - zip tied the sensors/wires neatly out of the way.
No issues with the (reduced) heat in the cabin. Maybe in a cold winter, but that's not an issue for me.
Good luck
Matt
Good luck
Matt
Exactly the same results. I did remove the relay...it's one of the square ones on the bottom of the box next to where the blower motor was. If your air stops working, you removed the wrong one.
what if i just simply remove the 30A fuse, will this be the same as removing the relay?
tried removing the relay, and it doesn't seem to want to come out.
i also go a red light in the dash: 1:00. I believe its the blower.
