Paint Experts C'mon In......Got It Back!
Noodle Jr.
So I took the Cactuswagen in for some work and the shop is having trouble matching the paint. I had them remove the front bumper and fill the license plate holes and also remove the 1B side skirts, repaint them and refit them because the adhesive was separating from the body. Anyway they sprayed the parts and I stopped in to drop off some parts and they looked great until they put them on. They said it wasn't close so they tried another sample and sprayed one of the skirts and called me in to look. Way too red compared to the car. Another thing that I questioned is the fact that they are using clearcoat and my car is single stage which even though it is low miles and the paint is in great shape it will still fade over time. My question is what happens if they can't get a match? BTW they were using the gas flap as their sample.
Also they let my battery go dead by leaving the hood unlatched......totally recharged it overnight then did the same thing again...........
I just had my nose done by a local generic bodyshop and was pretty suspect on his ability to use their spectrometer to match the Arctic Silver. Damned if I can tell a difference...............
oh man... no fun Cactizzle.
A good shop can match paint... takes some trial and error unless they get lucky. GR is a tough one.
Many shops will want to blend in adjacent panels to get it done. At least it's not a metallic!
I wouldn't want a clearcoat on a car without it.
My .02c
My .02c
Cactus: It CAN be matched. Whether they can match is another issue. I have had experiences both ways. The guys that are good can do it! Do not accept it unmatched, as it will bug the **** out of you every time you approach the wagon. Again, DO NOT ACCEPT less.
Raptor is correct - the issue is your shop's ABILITY to match - GR can most certainly be matched - even to a current fade. I think the highest suspect color to match is Arctic Silver as Ken mentioned. I was suspect as well at one point with an Arctic Silver match on a previous car, and it came out perfect.
GR match + competent shop = No problem.
Take it somewhere else if you have to, but do not accept a red mismatch.
Another mention...although everyone's monitor will display colors within pictures differently, I can tell from that shot of your front bumper that is WAY off from GR. Looks to be a much deeper red than GR on all 3 of my PC monitors.
I had the front of my Riviera Blue repainted and it also is a one stage paint . They had a problem matching the paint but somehow they solved the problem by mixing a blend of clear coat together with the blue paint and viola an exact
match .
So I believe if they know their stuff they can match it .
Cheers Guy
match .
Cheers Guy
Apparently GUARDS RED can also be INDISCHROT (also known as Indian Red) to Porsche. On my paint code label both descriptions are used. Thing is Guards Red paint code is 80K G1 whilst Indischrot is G3/LM3A/G1 or 84A/M3A in metallic. Confused? You will be, see this thread:
https://rennlist.com/forums/924-931-...-the-same.html
Hope it helps.
GR
Hope it helps.
GR
Cactus,
They should be able to match it. If you get a good match now, it will likely age fine since you take such good car of the paint anyway. Be sure to also look at the car in direct sunlight. You can get a good match in the booth, but occasionally it will look different in direct sunlight. "reds" are tricky, but be patient and it'll all work out.
Just had a cosmetic re-spray to bumper and fender last week..it's that time.
Good luck.
Good luck.
Did they paint a test card and compare it to your car after the card dried? The card should have been shot and then compared to your car in direct sunlight. The clear should not make a difference in color match but it may have more of a shine compared to single stage. Red can be a bit tricky to match but it can be done. I sent you a PM.
Are you sure they're using the correct formula for GR? The photo you posed doesn't look like GR to me. The reason I suggest this is because I had my '66 912 repainted once...It was a dark blue but the repaint came out an irredescent peacock blue. Then they looked at the code again and realized they used to wrong formula....Just a thought.
Contrary to popular beleif, the best way to judge a match on any red car is at night and not sunshine.
Red is tough.
AND do not let them blend the other panels. I would rather there was a slight bumper mismatch than ruin the fenders and bonnet aswell.
Good luck.
Red is tough.
Good luck.
