Semi OT: Tools, tips and tricks
Photo 1: A mini pry-bar I found at Lowes (<$4), great for getting you the gap needed to replace the trim gasket piece between the front fenders and the lower windshield body.
- 1/4" driver set w/ flex extension and 7mm socket. I use this for removing hose clamps, much better than a screwdriver esp. back on the inner MAF clamp.
- Spark plug sockets, magnetic and you don't have to tape the socket to the extension
Photo 2: I use the bolts with the (??) to measure ride height and then use the caliper to measure the length of the bolt, it gives me my ride height. 1 for front and 1 for rear. The other is a self made Hazlet tool for Bilstein strut nuts, 7/8" Lowes socket cut with a air die cut tool.
Photo 3: crows foot flare sockets, Triple square sockets, metric wrenches (purchased for torsion bar suspension system on my former '88 cab). Still use them occasionally.
Photo 4: Extension mag pickup w/ LED light, Sears bolt-out (just used on my 30k mi. service since 1 dist. cap screw wouldn't come loose)
Sears bend light (LED)
I just added a kinematic toe tool to my collection and in the process of making a setup for string lines...
Great idea for measuring the ride height with the "Coupling" nuts...
Here's my odds and ends. Picture 1: long "grabber" to get that nut you dropped when replacing the front hood strut, extending mirror to check hard to see places... maybe finding a nut you dropped when replacing the front hood struts, a curry comb to scrape rocks and picked up rubber off your Hoosier A6s after an autox, and finally a 1" crow foot ground down thin and to 27mm to get that
SAI check valve off while the engine is in the car.Picture 2: my favorite "bought this silly thing and might use it a couple times" tool, the crankshaft pulley holding wrench Porsche tool #9548
I recently bought a set of bolt out tools from craftsman similar to yours...sure enough, needed them last night for bumperette removal...worked like a charm.
Two things I find indespensible in my garage....
1. Bench Grinder...
I use it all the time for home and car. Most recent use? Sharpening my daughters extra large colored pencils that dont fit into any sharpener.
2. Air compressor.
Most recent use? Drying out the inside of my headlight lenses after a thorough cleaning (a job I know every 993 owner will appreciate after they see thier nice gleaming headlights in the sunlight for the first time!)
Next on my list are some High Quality calipers for exact measuring.
Good post!
Rennlist Small
Business Sponsor
Here are some that I do have images of:
Billet F-car O/F socket
360 pilot shaft
360 slave cylinder wrench -- this was before welding -- this bolt is a royal pain to get at
F-car flywheel lock (copy of another tool)
F-car tensioner adjustment tool (copy of another tool)
Wing element profile checking tool
I'll try to find some more cool tools
Must be nice to have CAD help making custom tools.....
I have a BMW K bike motorcycle oil filter that looks much like your F-car oil filter.
I forgot to include the 1" to 27mm ground crows foot for SAI valve, it works great.
I'm anxiously awaiting Andreas' contribution to this thread, I bet he's got some good ones.
i'll add one of mine, a 800 ft lb Tq wrench.
Stop by if you ever need your axle shaft nuts Tq'd
Mine - Brake job, cleanup / detail time. soap , cleaner & water, not good on the garage floor. use an under bed storage box to catch the runoff. like this one. Just dump after you finish.
Also works GREAT when taking off the small oil filter to catch the unorganized drips and rivers of oil. And you can just drop the filter in for later disposal.
