Making the spoiler switch-activated only...
What's annoying is that one of the most pleasing shapes in automotive history is ruined by what appears at first glance to be an elementary school lunchroon tray left sitting on the rear deck. It just looks frickin' silly, that's all.
As for cooling, I could stand for my car to run a little hotter...It takes forever to heat it up so I can check the oil.
The spoiler is a grille. Tons of air flows through there regardless of whether it's up or down.
Just think about it this way: How did 911's before the advent of the electric spoiler stay cool? And how does a 993TT, which doesn't have a movable spoiler, stay cool?
The real overheating danger with a 911 is when you're idling in a traffic jam and very little air is being pushed through the cooling fins of the cylinders and heads or through the oil cooler at the front of the car. As soon as you get moving, there is massive airflow over both the engine and the oil cooler.
The tails do "grab" the airflow -- but this aids aerodynamics far more than it does cooling. I've owned my 993 for three years now, and have never seen the oil temps on the highway even crack 200F. Highway driving is the one area where you really don't have to worry about oil temps, because there is so much air flowing through the cooler, and the RPM's are up, forcing air through the motor.
I'm not sure where everyone acquired this idea that the electric spoiler is a cooling aid (as opposed to an aerodynamic and aesthetic one). Sure, maybe the tail in the up position helps direct a little more air to the motor. But was the motor starved for air before? No.
I dont know about silly, but the aesthetics are definitely messed up with the spoiler up.
As for being annoyed: everyone is annoyed by stuff, small and large. It seems that even others being annoyed can annoy some.
The fixed tail is just like the spoiler going up, it just doesn't go down. The TT's have a different fan/pulley ratio to pull in a bit more air. I "believe" that the fixed spoiler pulls in more air, as the surface area is much larger to catch the air moving over it.
Our cars & 964's run hotter then the earlier cars, lets not forget the engine is quite a big bigger. It also runs more HP/ltr, this creates more heat. The 946 spoiler didn't cut it, so they made it bigger for the 993.
The airflow coming off the roof is moving fast as it moves down the rear window, & starts to break up, the spoiler creates a low pressure area behind it, pulling the airflow into the engine bay, that little spoiler wall, also helps to pull the air into the engine bay.
There is a very simple test, get a temp probe, put it in the engine bay, drive around @ 45mph, record the temp, then put the spoiler up, do the same drive, & see what the temp is.
Its not a matter of that. Its just silly to have the thing go up and down everytime one comes to a stop. If I designed the spoiler control, I would have had it come down on speed and time...not just speed.
I just put mine up manually after I start the car and it stays there for the duration of the drive.
This doesn't concern me in the slightest. My car doesn't get close to even running too warm, much less hot, on the highway, and yes, that included a month or two when my spoiler drive gear broke and the tail was fixed in the down position.
This idea of the electric spoiler being a key component of engine cooling is a fantasy. I'll make a bet right here in public: those of you who believe this, put the spoiler down and go drive your car down the highway. Then put it up and do the same drive. If you see any difference in oil temps, I'll eat my gym socks.
if you're driving the car, you won't see the spoiler
Noah, I messed with this too and couldn't come up with a good solution. In the end I just bit the bullet and sprung for the Ruf module. Yeah it's probably an unnecessary mod but arguably so are new wheels, sport seats, clear corner lenses, etc. If you take the "unnecessary" arguement to its logical conclusion we'd all be driving Hyundais.
This issue has been discussed ad infinitum. But I'm trusting RUF on this one. If my engine fries prematurely, then so be it.
btw, here's a post from back in 2006:
"It is a spoiler, not a wing. It "spoils" the flow of the air over the car, reducing the lift that is inherent in the design with the spoiler down. A wing would be required to apply "down-force". Somewhere on the web there is a comparison chart of various spoilers and wings done in a wind tunnel. I recall it included earlier Turbo tea trays, but I don't think it went beyond 964s. It might help with cooling, but those slats function when the spoiler is down also, as did early 911 grills."
I can hear it go up and down which gets annoying in stop and go traffic or on the streets around here with traffic lights every 1/4 mile. There is no reason for it to go up at 45 mph, if it was in any way necessary Ruf would not offer the module. Oh and I do like the look of the car better with the spoiler down-why does that bother you so much?
I haven't much talk about the needless wear and tear either. The RUF module seems like the answer but I don't know if its a $400 problem for me.
Does anybody know if this parts is still available?
