Where can I find 60k service details? Also, PPI items?
Porsche noob... getting ready to pull the trigger on a '95.
Looking for a list of the required items for the 60k inspection/service.
I'd also like your opinions on what should be addressed on a PPI. As well as compression check info (good numbers, bad, etc.)
Thanks in advance for the info. I look forward to joining the club.
Just about everything you need to know.
http://www.pcarworkshop.com/index.php/Main_Page
Direct
http://www.pcarworkshop.com/images/b...e_Schedule.pdf
Direct
As for the 60K, I'd add a couple things that aren't on the official list given the age of these cars; plug wires, distributor belts. There are other items in this category I'm sure, but those two come to mind first,,, (neither has been done yet on my car, AFAIK, at 113K miles.)
The 993 engine is one of the best of the entire 911 series. Their issues pale in comparison to that of other engines.
1996 and later cars are OBDII compliant, which means a clogged SAI port will cause the Check Engine Light to come on. The root cause of this is often worn valve guides. 1995 cars are OBDI, which doesn't monitor for that, so even though the ports and the valve guides are the same as in the later cars, any problems there do not result in a "I have to fix this NOW in order to pass my emissions test!" scenario. Indeed, there are some homespun remedies for cleaning out the ports and resetting the codes.
There are leak prone areas such as valve covers and timing chain covers, but those are annoyances rather than show stoppers. My car is as strong as ever even though it's now leaking like a sieve.
Do not let engine issues deter you from this model; again, by comparison to other 911 series, these are as bulletproof as they get.
What "reliability" issues? Elaborate, and we'll be happy to discuss/point in the right direction on some maintenance that needs to be addressed. But there aren't any issues with really any 3.6 air cooled engine regarding whether it will catastrophically fail (to use a Porsche water-cooled engine term).
Funny you should ask race911... I was wondering the same thing. I've read a few posts on the 996 section where people were happy they bought it over the 993 as they don't have the engine problems. But they did not elaborate on what those issues were. That was what sparked my question to you guys.
Ed, thanks for the feedback as well.
It is safe to say that every iteration of 911 engine has had an issue of some sort. Some are worse than others... the M96 engine has the potential for one of the most costly failures. The debates on this go on for pages at time on every board.
Yeah, name ONE of the air-cooled 911 engine issues that requires basically throwing the engine away and plugging in a factory reman unit?
Bottom line is that you can REPAIR air cooled, but you REPLACE water cooleds. (NOTE: this discussion does not include word one about which approach costs less.)
If we want to go chapter and verse, I've had my hands in multiples of all generations: 2.0, 2.2, 2.4, 2.7, 3.0, 3.2, 3.6 normally aspirated, 3.0, 3.3 turbo, AND the cobbled together variants.
