I'm so pissed off that the Kinesis Supercups won't fit over Big Reds!
Agent Orange
I need a 12mm spacer up front to make them fit and there is no way in hell that is going to work with the my suspension geometry.
I ran 12mm spacers up front with RS alignment specs and zero issues. However, if they're not working for you, all the better. Not confidence inspiring to have such a large spacer up front when you're driving spiritedly or at high speed. I removed mine shortly after install.
Agent Orange
Louis, I've measured this in the past, and the larges spacer I can put on the car without compromising safety is 6mm. Here's how I've done the math: the amount of tread on the wheel stud that the nut goes on has to be at least as long as the diameter of the stud. With a 6mm spacer I get that exact amount. If you feel this is incorrect in any way please let me know, I'd love to figure out a way to make this work obviously...
When I ordered mine from Wheel Enhancement they asked if I had stock brakes. Luckily I told them I was planning on upgrading them to Big Reds, so they made sure the offset (which I don't remember) was correct.
Ilko, I think I know what the problem is. I really like the look of the Kinesis supercup wheels (needless to say). But AFAIK, Kinesis have used a 17" wheelcentre for this wheel design as opposed to 18" wheel centres for the other brands (RH, Kerscher, Tramont etc.). This means that the back edge of the spokes of the wheelcentres with hit the big red brakes. My RH 3.6 speedlines fit over the big reds but they sit VERY close. The diameter of the wheelcentre though is 1inch larger than yours, which makes them fit. If you compare your supercups side by side (even a picture will do) against OEM 993RS wheels you will know what I mean. Look at the sizes of the wheelcentres and compare. Great looking wheel though. I bet they are still in great demand. Sell them and buy a set of 993RS speedlines? Just a thought..
Have a nice weekend
Have a nice weekend
Agent Orange
Yes Viggo, that is exactly the problem. And the centers are actually 16" on the Kinesis and 17" on the Speedlines. It could be corrected if the wheels were pushed out, but it's more effort than it's worth and I'll have to compromise in other areas such as safety and handling which I am unwilling to do.
Thankfully I didn't buy the wheels, but I've already gotten several PMs from people asking me to sell them
I did my homework on this before I moved ahead. Hope this helps:
https://rennlist.com/forums/993-foru...what-size.html
https://rennlist.com/forums/993-foru...-a-mirror.html
https://rennlist.com/forums/993-foru...-fit-rims.html
sorry, i meant that you don`t have to remove the hub. there is a spot where you can knock a stud out, put new one in and rotate to next stud. thats how i did mine
