Yet another - will these fit? (rims)
On eBay (wheels) - seller is being a bit recalcitrant with information, anyone from the 996 forum know him?
I did contact Wheel Enhancement (Dave was great) and we are guessing that most likely the wheels are ET 52 front and back. Especially as Gemballa website indicates that the 10" only come as ET 52 and ET 40. However, Dave did not rule out an older model that may/ or may not have been available.
Will ET 52 fit front AND rear on my NB 993?
For a NB 993 and 10" wheels, you want a rear offset of 65mm. So ET52 will stick out 13mm from ideal. So whether or not that'll work for you depends on what tires you want to use, how much lowered you are, what camber you have, and if you mind the tires sticking out a bit.
IMHO, I wouldn't bother, but you wouldn't be the first person to do it.
10" ET52 will fit your NB rears....esp if you stick to 285s as your fender clearance is reduced by only 1/2". If you go wider than 295 you may need to break out the baseball bat
A 10" wide ET52 wheel sounds like trouble on a NB.
I posted a close-up picture in anther thread so try a search. Good Luck
Originally Posted by VNTGSPD
Careful! I have Boxster LTW 5 spokes that are 9" wide ET52 and they rub slightly with 265 Continentals under extreme bumps. I have rolled fenders. There is no way I could fit 285 without rubbing on every little bump.
Weathergirl
David, your sig shows the wheels appearing to protrude past the rear fender!
Russ, check out these recent pics of 18x10x58mm offset rears on a narrow body. Very close. Different people have different tolerances for clearance. And some people live where there are bumps and potholes.
https://rennlist.com/forums/showpost...0&postcount=29
Check out these recent pics of 18x10x58mm offset rears on a narrow body. Very close. Different people have different tolerances for clearance. And some people live where there are bumps and potholes.
The pics below are from eBay and supposedly shows 315 on 11" ET65 with fender rolling and no rubbing. This set up decreases fender clearance by 15mm...which is more than the 13mm decrease from moving to 285 on 10" ET52 vs the factory 285 on 10" ET65. I have not seen this car in person so can't vouch for the fit (315s on ET65 seem aggressive to me).
King of Cool
As you can witness from previous posts, a lot depens what camber setting you have.
I have 10" wheels with 52 ET, 285 tyres with fenders rolled and no rubbing but I have -3 camber.
Originally Posted by Flying Finn
As you can witness from previous posts, a lot depens what camber setting you have....
First of all - thank you Rennlist.
I really appreciate this level of discussion!
OK - time to fix my ignorance (yeah right )
What is the (effective) difference between 265/ 285/ 315 tires?
Is there a difference in driving/ steering/ handling/ comfort/ speedometer reading?
What is the effect of a more negative camber? Any disadvantages to changing the camber over rolling the fenders?
As always, with this garage queen, I'm street only, and at least a year away from being out of SUV height.
Update!
Seller has turned out to be totally cool.
Front wheels are 8.5x18 ET 46
Rear wheels are 10x18 ET 52
Now, will these work WELL for a NB C2? (Recognizing the rear issues as discussed above, but now concerned about the appearance, function, and lack of bump-steer for the front.)
How often do you go through rubber with that much negative camber?
Russ: I'm running 18" technologies but wanted to fill out my fenders so I put on spacers. I'm running 7mm in the rear with 65mm offsets and 14mm in the front with 56mm offsets. This effectively gives me the equivalent of ET58 in the rear with -1.25 camber and ET42 in the front with -1.45 camber. My wheels look as aggressive as as I'd want them to. Any wider might start looking out of place for a DD. The pic shows the car with spacers but with OE camber settings before I went more aggressive.
The fronts will fit fine and will look awesome. I think the rears will fit too but it'll be tight and you'll need to go at least -1.5 camber and/or roll the fenders. Nice wheels.
Update!
P.S. I've replied to your email.
