Rear Axle Removal...
#46
Does this all apply to the Tiptronic?
Stock suspension, but it seems like I don’t have enough room on the inboard side to get the axle shaft through the hub.
staring at it, looks like hub has to at least loosen if not come off.
#47
This included dropping the sub-frame to get the control arm that holds the drivers side shock mount in place as the eccentric bolt hits the headers.
After much manhandling -- the axles are out -- in the process of rebuilding them.
