Thanks... Do i need to drop the motor to do the job?
Yes, could be done with engine in, but it is time consuming and a bit acrobatic. At the dealer, they drop the engine.
If you need a guide through, there is one as a TSB on pcarworkhub, or
let us know.
I know I waited a long time to do the recall but I've been waiting for 3 months for Momemtum Porsche, here in Houston, to get the parts. Seems a little long, doesn't it ?
I just had the recall done a few weeks ago and my dealer actually had the parts already. When I checked the parts inventory in the US they had lots of harnesses in stock so you should double check with your dealer whats going on since the parts are in the US.
911CZ - Did they have the 993.xxx, or the 000.xxx part number in stock. Don't really want the 993.xxx. one ;-).
Already downloaded the TSB. The only hard part looks like the starter area, as I dont have a lift. But I dont need to drop the motor, which was my biggest worry.
Update... Called Pelican, and they wanted to VIN number to check if it qualified, which it did not. Called local dealer and they had it in a week. $175. Beats $950...
Anybody have the harness repair kit number for the turbo cars?
000 043 204 62
1 Part set for Turbo engineContains:
1x - Engine wiring harness (993.607.016.12)
1x - Adapter for heating connector (connected to wiring harness)
3x - Tie wrap
964 110 227 00
1 seal
999 707 326 40
2 o ring
999 512 460 00
1 Single-lug clamp
000 046 205 26
1 Adapter harness for secondary air switch over valve. See Table 1 to determine if needed.
The affected Vehicle Identification Numbers are contained in the following VIN-Ranges (Meaning not every car may be effected): WP0AC2992TS375065 to WP0AC2992TS375924 (U.S. Vehicles)
Thank you @il pirata
my car is an Euro spec, 25k miles (been parked for the last 8 years) look at the pics of the harness....
Originally Posted by il pirata
000 043 204 62
3x - Tie wrap
964 110 227 00
1 seal
999 707 326 40
2 o ring
999 512 460 00
1 Single-lug clamp
000 046 205 26
