993 Forum 1995-1998
Engine wiring harness
Old Nov 12, 2009 | 05:18 AM
geolab's Avatar
geolab
Originally Posted by e3photo
Cheers, Emerald
You are most welcome, Emerald
Makes my participation in this thread not completely regretful
Old Nov 12, 2009 | 08:11 AM
Bill Verburg's Avatar
Bill Verburg
Very good and accurate info, now all I need is a tip on a cheap ECU upgrade, as I have the earliest model, and don't believe it will work with V-ram
Cheers,
Emerald
If you have the recall engine wiring harness mentioned above it has all the connectors for both vram and non vram applications, any 55 pin 993 chassis harness and DME will do fine w/ it, the diffference between vram and non vram DME is mostly in the chips, though there are a few wire differences that are easily repinned.
Old Nov 12, 2009 | 05:55 PM
JM993's Avatar
JM993
In my experience, the earliest of 95 ECUs do not have the functionality to support VRAM. Please see the link at the bottom of my sig for more info.
Cheers,
Joe
Old Nov 12, 2009 | 07:24 PM
e3photo's Avatar
e3photo
jmarch, I was basing my assumptions on having read your thread. I have an early 95 ECU (no drive block) – Porsche # 993.618.123.02
Do I need a newer ECU, and maybe keep the harness, or get new harness and ECU, and do I recall correctly that 96's can not be chipped?
Thanks for all the help.
Cheers,
Emerald
Old Nov 12, 2009 | 07:32 PM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
Geo, I always appreciate your input, I find it quite valuable. I can't tell you how many of the TSB's you posted awhile back that I've downloaded.
Thanks again for your contributions.
Old Nov 12, 2009 | 07:36 PM
JM993's Avatar
JM993
Emerald,
I've answered your question in the link below. See post #49.
Cheers,
Joe
Old Nov 12, 2009 | 07:43 PM
Bill Verburg
I'd need to look at the '95 v1 wire diagrams but all you need is to hook it up the way RS and RoW vram are run by using what on the US cars is the SAI circuit(pin 32) for the resonator flap and the '95 resonator flap circuit(pin 1) to drive the vram. Of course you need a RoW vram chip to do that.
Old Nov 12, 2009 | 09:34 PM
JM993's Avatar
JM993
No need to look it up, you're right. Provided, of course that a recall wiring harness is used.
Old Nov 12, 2009 | 11:07 PM
e3photo's Avatar
e3photo
Oh Great, so I just do an SAI delete, and use the pin for the V-ram?
Thanks Bill and Joe. It would be great not having to get another ECU and harness.
Cheers,
Emerald
Old Nov 13, 2009 | 12:11 AM
JM993's Avatar
JM993
Cheers,
Emerald
Not quite. You need a later OBD-1 ECU and a chip to run the VRAM as I describe in the VRAM DIY.
I'd source a later 95 ECU w/o Drive Block which is Porsche # 993.618.123.03 / Bosch # 0.261.203.674. You can chip this ECU to operate the VRAM. As an alternative, you can troll Euro ebay (probably German, British or Italian) to source a 993.618.123.11. This is the Euro OBD-1 ECU w/o drive block. It will be plug and play for the VRAM - no chipping required.
Since you have the recall wiring harness, you will have all the VRAM connectors in place.
Cheers,
Joe
Old Nov 13, 2009 | 01:13 AM
e3photo's Avatar
e3photo
Oooops,
Thanks for clearing that up Joe. I guess I'll start looking for another ECU.
Cheers,
Emerald
Old Nov 15, 2012 | 09:00 PM
levtron's Avatar
levtron
I have a 96.. Looks like my harness got fried by an act of god... you can see my other posts about my crazy fan accident.
So while fixing it... looks like the entire harness fried.
Does anyone know if the 000.043.204.61 is good for the 96 with Vram, and whether this is still available? It will kill me to pay $921 for a new one.. I can get a used one for about $450... but that has other potential issues.
Also, do you need to drop the motor to change the harness?
Old Nov 15, 2012 | 09:35 PM
e3photo's Avatar
e3photo
I think the same harness fits both v-ram and 95's
Old Nov 15, 2012 | 09:37 PM
levtron's Avatar
levtron
Thanks... Do i need to drop the motor to do the job?
Old Nov 16, 2012 | 01:29 AM
GC96's Avatar
GC96
Shows up when I try the part number here http://sonnenporscheoemparts.com/par...&siteid=215405 so I would assume it is still available. The price is pretty good as well.
GC
