993 Forum 1995-1998
Rennline Billet Aluminum Shift Knobs **Product Release**
Old Nov 9, 2009 | 03:51 PM
Rennline's Avatar
Rennline
Basic Sponsor
Default Rennline Billet Aluminum Shift ***** **Product Release**
Rennline Billet Shift **** **Product Release** $95
Unlike most shift ***** on the market, Rennline’s are far from “universal”. Universal usually means that it will nearly fit some applications and will not fit the rest. All Rennline shift ***** are CNC machined to fit specific applications, eliminating the concern of missing a gear due to loose or detached shift ****. There is no need to cut, drill, or modify your factory shift lever to install. All of our shift ***** are the ergonomically correct 1.875” diameter and have rubber trim rings installed at the base. Available in Silver and black finishes, for cars with or without integrated shift boots. Fits 964/993/996/997/Boxster/Cayman 1989-2010 w/ manual transmission
WWW.RENNLINE.COM
Orders@Rennline.com
Ph. 213-224-7393
Old Nov 9, 2009 | 04:09 PM
dbf73's Avatar
dbf73
looks nice - how do these go on when you have the integrated boot with the factory ****?
Old Nov 9, 2009 | 04:34 PM
MDamen's Avatar
MDamen
I didn't know that 1.875 inches is the ergonomically correct size for a ball!
Old Nov 9, 2009 | 04:53 PM
AOW162435's Avatar
AOW162435
Seared
Now you know.
Andreas
Old Nov 9, 2009 | 05:09 PM
Rennline's Avatar
Rennline
Basic Sponsor
Here are the installation instructions to show how the factory boot is retained. Installation Instructions
Old Nov 9, 2009 | 06:14 PM
Mike J's Avatar
Mike J
Aren't your ***** that size?
Old Nov 9, 2009 | 07:13 PM
trophy's Avatar
trophy
I think I will go and measure mine now...... Hold on, I'll get my wife to measure them tonight.
Old Nov 9, 2009 | 09:52 PM
MarkD's Avatar
MarkD
Just a tip, you don't need to remove the center console to pull the ****.
The base ring unclips from the left side with some downward pressure.
Then slips out of the right side clips.
The boot with base ring can then be removed through the top.
Hope that helps...
(dang, the server is really dragging tonight... )
Old Nov 9, 2009 | 11:13 PM
David in LA's Avatar
David in LA
Great looking shift ****...reminds me of the old Techart and Ferrari *****. Are there any plans to engrave a 6-speed shift pattern onto the know?
Old Nov 10, 2009 | 12:24 PM
CAHRERA's Avatar
CAHRERA
The website is showing "Out Of Stock" are they all sold out already? That's on both Black an Silver.
