RS Motor Mounts Look Cheesy ???
#31
Seared
Also IIRC some feel that if going with Wevos on a non-turbo you should consider reinforcing the carrier using the Rennline kit as they are stiffer than the RS mounts.
#33
#34
Wevo's specialty is doing things better than the factory, although almost always more expensively. This case is an exception. The Wevo design is more modern and use a urethane vibration dampener rather than the factory rubber. And when you wear out the factory part, you have to buy new mounts. With the Wevo's all you have to do is buy a couple of new urethane dampeners, which IIRC is twenty bucks. And you have two variants of stiffness to choose from in the form of blue or black pillows. Click the link above. No affiliation, just a satisfied customer.
Bob-
#35
I have the WEVO mounts as well and like them. The fit and finish and function is excellent.
The only issue I have is that I have a minor rattle in the rear shelf of my car that is now magnified by the WEVO mounts when engaging the clutch. Since I daily drive my car, it kind of sucks. The upside is that the mounts result in a very slight change in engine growl heard in the car that is really nice. The factory mounts were too quiet.
Bob -
I might consider a trade if you are thinking that WEVO would suit you better.
David
Bob -
David
Thank you.
Bob-
#36
Those are custom environmental condition sensors. If they detect a presence of more than .001 microns of dust in the engine bay the boot pops open and the area is flooded with 303 Aerospace Protectant from nozzles protruding from the garage ceiling.
#40
I should have known that! I am truely embarrassed
Bob-
#41
Good Luck!
David
#42
This place is sometimes better than Comedy Central....that is hilarous
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Andreas, WOW!!! Everytime I open my deck lid, I will feel inadequate.
#43
Seared
Keep your RS mounts. There is next to no difference in the ride between the Wevo's and the RS mounts.
Here is a thread that I posted some time ago that you may find interesting:
https://rennlist.com/forums/993-foru...nt-thread.html
