Keyless entry
I did a search on this before posting. My '95 has got the basket handle, and the immobilizer system, but the previous owner didn't give me a keyless entry remote. Should there be one? In essence, does the immobilizer and keyless entry go hand-in-hand?
If you don't have a remote, how do you know you have an immobilizer?
I always thought that if you have a 1995 with a remote, then you have an immobilizer. And vice versa.
I have neither, but installed a RKE per the long DIY thread a few years ago.
Anyone have a link to the DIY? I'm dying for keyless entry.
I'm also on the same page as Eric. If you had the key fob, you have an imobilizer, if not then you dont. My old man's 95 has the imobilizer, mine does not and is an earlier build than his. Both have the basket handle
I wrote the DIY a few years ago. It's not really long or complicated, we were just discussing various little improvements and details after the initial post. BTW, my cheap JC Whitney remote still works today, 5 years down the road. Probably the best $30 I've spent on this car.
Here's the post: https://rennlist.com/forums/993-foru...-95-993-a.html
Here's a discussion on whether all cars with immobilizer have remotes (the short answer is "No"): https://rennlist.com/forums/993-foru...mobilizer.html
...Here's a discussion on whether all cars with immobilizer have remotes (the short answer is "No"): https://rennlist.com/forums/993-foru...mobilizer.html
Plus, I can't see how a 993 immobilizer could work without a remote, since you need the remote to disable the immobilizer.
I'm pretty sure my car has an immobilzer - I don't have a keyless entry remote as well.
I tested by locking the doors with the key. Then I waited for the alarm/immobilizer to arm (wait till red LED lights flashes slowly). Then I tried to start the car with the key. The car would not start and the alarm would go off. The car was definetly immobilzed.
In general, if you're not SURE you have an immobilizer, then you don't. The immobilizer is a fairly big annoyance; after a minute or so, it immobilizes the car whether or not you've locked the doors. You insert the key, turn it, and nothing happens until you notice the immobilizer light is on. Then you have to press the button on the remote to turn off the immobilizer. Kind of annoying. If you haven't experienced that, then you don't have an immobilizer.
I don't see how you concluded "No." Boris seemed confused between the difference between "immobilizer" and "alarm". So it's not clear he had an immobilizer.
With the sorry state of searching here I can't confirm.
In either event, I'm happy I definitely don't have one in my car.
1. The immobilizer activates like on 1996+ cars. If so, you'd have to find a way to turn it off (so you could restart the car) without using a remote control, and I don't know how you'd do that.
-or-
2. It DOESN'T activate, meaning the "immobilizer" is completely invisible to the user. That being the case, how would you even know you have an immobilizer?
Eric, it's actually an interesting qustion.
At some point in time I was replacing the security box under the passenger seat. The first one I got was, apparently, from an immobilizer car. No matter what we did with it, the car just would not start. Played with the Hammer and it still didn't. The car, however, did crank, so it might not have been immobilizer related if you are saying that immobilizer kills the starter completely.
