Lesson Learned, Check Dipstick!
I was freaking out about my car burning oil all of the sudden, I changed the oil myself, added oil until the gauge was almost to the top warm. In the matter of 300 miles the oil gauge went to the middle. Kind of freaked me out since it's really never burned oil before. I checked the dipstick when the engine was warm yesterday. It was to the top of the twists and the interior gauge read only half full. So I think I was overfilling it and it was just burning off until technically full again.
No more trusting my gauge anymore. Can anyone explain what happens when you overfill the oil? I didn't get any smoke but a buddy driving behind me said he could smell oil under throttle. I've read oil gets into the intake when it's overfilled? Can anyone describe what that means and how it happens?
thanks!
thanks!
thanks!
thanks!
So how does the oil get into the intake? I didn't see that in the other thread either and was curious.
I found that for my car keeping the oil in the middle of the dip stick range is best. Mile after mile it stays in the middle. When I use to fill it to the top of the range it would burn/use the oil until it was right back to its sweet spot and then stabilize. The gauge reads at the bottom of the range when checked.
RL Technical Advisor
This is definitely something to avoid as oil burning lowers the fuel octane, makes deposits in the chambers and piston crowns, plugs the cats, and fouls the oxysensors.
Without question, reading the dipstick is a challenge however its well worth learning to read the subtlies of a proper oil level on the thing and not relying on the guage to make decisions about correct levels.
I've seen far too many overfilled cars and have seen the consequences of using the guage to decide whether to add more oil to the system.
Look for a little bubbling action on the dipstick to find the level, view in direct sunlight, blot with a paper towel, etc.....
If you think you are reading the dipstick correctly, but after the 11th time you're still not sure, let the car idle for 15 minutes or so. The oil temp gauge should start to register higher, and then when you check the oil on the dipstick again you will see a higher level as well... Then drive around for awhile until the temp gauge shows normal operating temps, check oil again and it should be back at the original level you found.
