How to stop rattling shift knob
How to stop rattling shift ****
I've got the stock C2S shifter and the top plastic section rattles. I can't figure out if there is anything to tighten to fix this. I've pull the entire console and shifter/leather boot out, but I can't figure out if there is a way to tighten the plastic part. I did a search and found some info on similar style shifters that talk about a set screw under the leather, but I dont' see a way to get under the leather on my shifter. Any guidance is appreciated.
I have seen some of these ***** loose, some tight...
If there is a screw it will be on the back side of the **** itself.
A year or so ago I unsuccessfully attempted to take one of these apart and finally (this was very hard for me!) gave up. I didn't want to damage the ****.
Since the shift pattern insert cannot be removed without damage, there should be some sort of screw that clamps the metal down on the leather and that screw must be accessed from the back side of the ****. There is a small opening on the underside of the **** but I could not find a screw.
The only other possible option would be that Porsche sealed off whatever holds it together with the shift pattern insert... but that would not be what we normally see on these cars. Stuff can usually be taken apart.
BTW, you may already know this but you can pop off the shift **** and boot pretty easily with the console in the car. Just push down on the metal ring on the driver's side. There are 2 spring clips in the console that the metal ring will snap out of. There is a DIY on pcarworkshop.com with some helpful pix: http://www.pcarworkshop.com/index.ph...center_console
That's what I did for my MY02 shifter and fixed it. For mine, I could actually detect a little free play fore and aft with the shift **** before the fix..... grwoolf and Mark might be referring to a different rattle.
Adding thickness to the shift lever won't help this issue.
If the whole thing is loose, that would work, of course.
That is correct, it's the plastic (silver/grey) section that is rattling. The main part of the **** that is covered with leather fits nice and tight on the shift lever.
I couldn't find any hole or screw on the underside of the **** except the large retangular hole for the shift lever. The leather can't really be pulled back too far because it can't be pulled over the wide section of the ****.
If I can't tighten it or take it apart without breaking it, I was thinking about getting a hypodermic needle and shooting some epoxy under the plastic part, but I don't really know how big the void is and whether this would work.
Sometimes it's the simple things ain't it? : )
In audio, they have discs to prevent cone tips from digging into your hardwood or scratching. Some folks just use coins, I've seen another guy that lost one of the discs, and used a bottle cap.
No to hijack the thread, but I have the same **** and the sheet metal that holds the set screw inside the **** broke.
is there any other way to attach this thing to the shifter securely?
Slide the floss in between the angle-cut top **** and the rest of the shifter and make a few loops around then carefully cut the ends off. It'll make perfect sense once you look at the ****.
Don't spread this too much, Porsche will put a sticker over the label of $2 floss packs, give them a part number and sell for $83 bucks as a "Shift **** Repair Kit." : )
