Springs!
Thanks Rich
Notice the positions of the spring support collars.
I was just above 25 in. from floor to fender gap front and rear.
How does this compare with your settings?
They are the H&R coilovers
The cure was to install a ROW MO30 spring set ....
Argh, this isn't really what I wanted to hear, but I guess it could be worse. Is there any way to tell (part numbers, etc) whether I have HD's or H&R's (or does Bilstein even make the shocks for H&R...I thought I read that on here in a few places???)
Did the spring noise up front sound clunky and tinny at the same time by any chance? Thats how it sounds to me.....
Bilstein most likely makes the struts in the H&R set.
These are of the fronts.
First up is the spring while the car is jacked up. You can see the markings of the spring here:
Second is a shot while the car is on the ground. Notice how stacked they are. The first 4 to 5 coils are resting on one-another.
This cannot be right and must be where my noise is coming from? With the car jacked up I can rotate the spring around its so loose. It almost seems as though the springs are FAR too weak for the weight of the front of the car.
Does anyone know anything about the markings/numbers on the spring? Clearly they are for a 993 as noted but why are they set up this way? Is this possibly correct?
Any help is MUCH appreciated. I'm about to rip them out and put in something else all together unless you guys can help me fix this or determine that it is, somehow, correct.
It looks like the part numbers are consistent with both the picture that icelatte posted, as well as the H&R web site. What have I missed??? Do I possibly have Bilstein HD's up front and H&R's in the rear?
Part numbers are the same as were on my set.
29954 VA
The fronts also had a label with H&R X/T in front and H&R H/M in the rear. Wonder how old your
set is?
The way you're describing it, it does seem like the spring rate is far too low.
Time to call H&R in the US?
29954 VA
set is?
I also noticed the logo on your set is blue where mine is red in the rear and missing the logo in the front????
The last time I saw a coil spring look like that (in its normal resting state) was on a 3rd Gen. 4Runner with progressive-rate lift springs from Performance Products. It too had the first 4 or 5 winds mashed together.
I would opt for something else.....
Andreas
Andreas
I'm wondering about the health of the struts as well. Though not ideal, you could start with getting Bilstein HD fronts only and springs vs cost of seeing if H&R would rebuild struts/replace springs.
, for in attempting to increase the front height ... this was the first revelation . Then, this snafu occured . Eventually, I went to the progressive ROW MO30 .... which entailed rethreading the Bilsteins.Well .... you get the picture...
The H&R fronts are a progressive spring type that in effect, use 'extra' closely spaced coils at the top to achieve the progressive spring rate - all wire stock is of constant diameter, as are the coils: this causes the top several coils to be 'in bind' at static height, so a higher rate is experienced on compression than on rebound ( once the spring is extended beyond static height) .... at least, that's how I understand it.
The consquence of this is that the 'binding' coils clatter away in routine driving on all but perfect surfaces - and really wake you up on expansion strips, etc. Hopefully, not all sets perform like this.
Anyway, I rode that horse to the bitter end, ditched the H&R's, and installed the front ROW MO30's/rear ROW TT's. The fronts are also a progressive design, but are executed quite differently. The OE Porsche units are fabricated with a tapering wire diameter, having a coil count, spacing and diameter more like stock units. The variable wire thickness provides the variable/progressive rate ---- without any coil bind and associated banging & clashing.
Much of the exercise in modifying suspensions, and the results achieved, is predicated on the desired chassis height: my goal was modestly below ROW 'Sport', and settles in at ~138mm/124mm f/r IIRC: those that lower further towards RS height likely have a far better experience with the H&R's, for I'm guessing that is closer to H&R's intent.
