I can't seem to find the DIY-How to remove engine tray?
How do you remove the engine tray without a lift?
I have both the tool kit jack and a floor jack. If I unbolt the tray will i be able to remove it by jacking up both sides of the car? Anything to watch out for?
I was going to paste that link, but I guess you already found it.
If you just unscrew it and pull it like Cactus says, you're in for a surprise!
You need to jack the car up on both sides, or back the car onto a couple of wood planks. You need a couple of inches of clearance to be able to remove the lid after you loosen it up.
