WTB: RS Shift Rod
#136
Hi.
I like this forum...alot more active than the 964 turbo one.
I was looking at PET and it appears the solid linkage is the only option for 964s, albeit a few part numbers.
I know you are 993 guys but any thoughts? I haven't been under the car to look myself at what is really in there.
Thanks.
RT
Thanks.
RT
I'm not totally sure... never got into that part of my 964 when I had it.
I agree, PET seems to indicate that there is already a nice solution in place.
If someone had pics of the setup that would help...
#138
Mark & Darin, Got the "golden rod" and RS shifter and fort in this weekend. Easy install and the shifting is sooo much better! Sent the core back to you today (w/ a check). Thanks for all of your hard work, Tony
#139
We just made our prototype over the weekend and shipped it to a RLer to try it out.
We are combining this forward rod with a short shift lever and fork, the OE RS Porsche parts.
It is similar to the Weltmeister kit, except it will be all stainless steel and a complete bolt in kit. The Weltmeister kit requires some drilling/grinding, etc.
Ours will be a bolt in replacement and includes the RS lever and fork.
Shoot me an email if interested. fdmotorsports@comcast.net
#144
funny you should ask... yes.
#145
#146
If anyone has the front rod installed after already had the rear (solid) rod inplace please post your review. I'd like to know the improvement of the front one.
thanks
thanks
#147
unless the nylon ball/socket joints are very worn, I am not sure you'd be able to feel much of a difference. You might be able to but it would be slight. Assuming all is in good working order, most of the slop is in stock the shift rod itself.
There are 3 reasons to replace the front rod:
1. The nylon ball/socket joints get sloppy and can pop loose, leaving you stranded
2. The kit also replaces the stock lever/rod with the RS parts. Shorter shift throw.
3. It is a really cool upgrade.
Some people here have made their own. Just need a few parts, some cutting/grinding and, in some cases, welding.
We are making a kit for those who don't want to do their own.
Our prototype pic below (final version will be all Stainless Steel)
#149
hn,
Thanks for the input.
