Finally a plug-n-play LED solution for 964/993 gauges
#76
Don't bother with cheap Chinese 74 bases you might find on ebay. They wont fit well and contact is mariginal at best. Buy the Superbrights indicated in post #61 above - they are a direct fit and work well.
http://www.superbrightleds.com/morei...-led/223/1040/
#79
How about these 74s:
http://www.superbrightleds.com/morei...edge-base/228/
Anybody fit these ones or do they not have the base?
#80
As deekay911 posted, the problem is finding the base to fit the leds into. This is where I am stuck and getting aggravated because I cannot find bases.
#82
Anyone tried these B8s? They looked like they would fit.
http://www.superbrightleds.com/morei...panel-led/223/
#83
#84
Like aribop I cannot find the bases to make these bulbs work.
Can any of the engineers around here describe a way to use the existing bases (for the filament bulbs)?
What about the feasibility of pulling the led out of these and then using the bases?
Finally, while deekay911 points out that the "Chinese made" 74 bases are of poor quality and fit, can anyone source any bases anywhere? (I remember there was a great electronics parts store in St. Louis back in the late 80's...)
#85
Sonny1
#86
#87
The issue I have is that I went with aftermarket gauge faces and the speedo & tach are very "spotty" with current incandescent bulbs - almost to point of not being visible at night.
What led bulbs did you use to replace the buttons on the CCU and in the ***** on the dash?
#88
Interesting information from tech support from the folk at superbrightleds.com!
On 7/8/2013 5:37 PM, Russell Burton wrote:
Customer Name: Russell Burton
Customer Email: doctock993@gmail.com
Are these bulbs: 74 LED Bulb - 3 SMD LED Wide Angle Wedge Base Part Number: 74-WWHP3 | UPC: 847781010688 a DIRECT replacement for incandescent/ filament bulbs? Specifically, can I use these LEDs in bases that currently hold filament bulbs? If not, what kind of modification will need to be done? Thank you in advance!
Gary Reising <sbl-support3@superbrightleds.com>
6:11 AM (9 hours ago)
to me
Hello Russell,
Yes, they should be plug & play, no modifications necessary.
Thank You
Gary Reising
Customer service/Technical support
superbrightleds.com
"Like" Us On Facebook - www.facebook.com/superbrightleds
to me
Hello Russell,
Thank You
Gary Reising
superbrightleds.com
#89
I bought the
Part Number: B8.4D-WHP | UPC: 847781010404
They work great! You do need to get a key and bend the metal tabs on each side at about a 80 degree angle. If you don't the LED will fall out of the gauge. After you get it to say put it works great!
One thing to not try, don't use super glue.......
Here i changed the left 2 of gauges. I'm going to do the other 3 when I get more in.
#90
I bought the
Please take a pic. We would really like a see it using our gauges.
Thanks,
Ken
