Finally a plug-n-play LED solution for 964/993 gauges
#166
They go pretty low (low enough for me at least).
One approach that you could consider if you are concerned about this would be to buy a couple of the 74-WWHP3 LEDs and install them in the fuel/oil level gauge and see if they go low enough for you. The only difficulty in this would be that you would also need to buy two of the holders and then buy more later if you like them. Or you could buy enough of the holders to do all of your instrument lights in case you like these LEDs (this is what I did - I figured that it was worth $10 to have them if I needed them).
Re the warning lights, you might buy the 2 and 6 lumen versions in amber and red and try them both in the fuel/oil level gauge and oil temp/press gauge to decide which you like better. This was the approach that I took - I bought one of each of the LEDs that I was considering and then followed up with a second order for the ones that I decided I wanted.
I gather both the 8.4D and 8.5D bases will fit ok in this application? Earlier on, you asked about the difference between them but no one chimed in.
Good idea to order a sampler, that way I can also evaluate some other options eg xenon white and amber illumination, and different brightness warning lamps. Guess doing two orders didn't occur to me because:
A) Tore's LED kits have spoiled me and made me lazy (wish he would do one for the gauges but I'm not patient enough to wait), and
B) here in Canada we usually pay brutal shipping fees from the USA so it has become habit to only order once.*
Thanks again for the info: you really should consider doing a DIY writeup and posting here and on Pcarworkshop!
*Frequently shipping to Canada - if the vendor will even do that- costs as much as the goods themselves, whereas you lucky folks south of the 49th get free shipping as often as not. Count yer blessings.
#167
Brian,
Both bases will fit (I verified this when I tried my assortment of LEDs). The only difference is that the tabs on the 8.4D bases need to be bent a bit to make the holder fit tighter (they are too loose as received) while the tabs on the 8.5D bases need to be bent a bit to make them looser (as received they are too tight to allow installation)
Re the shipping, it is unfortunate that your costs are substantially higher. Probably not as quick either (I got each order from superbright LEDs three days after I placed the order). Oh well...
Good luck with this.
#168
Brian,
#172
Led lights
Finally got around to installing the super bright LEDs and bases (UK).
Took about 2 hours. Moved from left to right cleaning the earwax from the rubber mounting rings and instrument nacelles. Followed Tore B!s directions about removing tach ring then tach from right- worked like a charm w/o steering wheel removal. Definitely make sure all bulbs/contacts work before reinstalling-polarity never an issue but several of the holder side contacts had to be " adjusted" to encourage bulb to light. Used a light application of 303 on the rubber rings to ease reinsertion. Surprised to see that I had 2 incandescent bulbs out-- never noticed before. Personally see no great need to replace all warning lights as they are pretty bright as is and smaller, younger and more dexterous fingers would be highly recommended. Very pleased with results and looking forward to a midnight run.
#173
lots of great info here thanks - I see WARM white LED B8.4's were mentioned
but on superbrights website and EBay I dont seem to be able to find them - only COOL white - ... any chance anyone has?
thanks for the help!
Matt
Matt
#174
https://www.superbrightleds.com/more...rofit-car/228/
you need to get the bases separately, there is unfortunately no complete one. you can get the bases here:
http://www.crazyleds.co.uk/509T-3xPLCC-2-LED.html
Assembly is straightforward, but you do have to bend the side tabs a bit to fit our application. I just bent one to fit and then bent all the others the same with some needle nose pliers. I didn't have any tabs break, but I'd order a handful extra just in case (they're cheap anyway).
it is worth the effort though!
#175
If you go back to Page 9 (post 126) on this thread there is more information. Make sure to order extra bulb holders as some will give you problems.
Don't forget to buy 2 more LEDs from the climate control unit!
#176
Can you update with a few more pictures of the amber LED lit gauges. I currently have the "warm white" installed and I'm wondering if I might prefer the amber setup. More pictures would help me decide.
#177
OK thanks Xcold & AZT ... I was going the wrong way looking for the one piece solution though if the UK holder is the right shape for those bulbs it wont be a hassle to fit them and bend the tabs etc..
Not sure the amber would look right - I quite like the 'newness' of the cold white but the warm white would soften and blend in better I figure ... amber might look too modded
#179
I would like to update my instrument lights but I have a question about what type of bulb is needed.
DobermanDad used B8.4D bulbs:
However, AZ Targa used B8.5D bulb holders:
It seems odd that both will fit but they evidently do. Is one closer in size/geometry to the OEM bulb holders? Or is either one OK to use?
#180
Re warning lights, my manual C4S coupe has 22 (4 orange/amber, 4 green, 1 blue, and 13 red) this total includes the turn signal and high beam indicator lights. Note that the specific number of warning lights that you have depends on how your car is equipped. If you have a C4S or turbo you will have a red brake pressure warning light, otherwise no. And you will have a Tiptronic Emergency Program warning light and/or a convertible top warning light if you have a Tip and/or cabriolet (I don't have either).
As indicated in previous posts there are 11 instrument lights (3 for spedo, 2 for each of the other instruments). I went with the warm white lights recommended by AZ Targa and am very happy with them.
I don't know about the accessory lights.
Anyway I have three of the four warning lights in the clock on LEDs and the AirBag on stock. I'll try the other warning lights to see if they are as sensitive as the AirBag. If ok, I will order the remaining 'B8 LED Bulb - SMD Instrument Panel LED' in their respective colors. I will also try other bulbs to see if I can get around this problem.
Wilson
1997 993 Turbo
