Any one w/ a DAS bar and PP or Profi XL
care to post some pics?
I've seen PPs where the shoulder harness holes don't line up too well w/ the DAS horizontal where the harness mounts. Don't know how much of an issue this really is. But pics of either seat installed would be helpful
just some additional data, I'm 6'1 220# and need the wider seats, currently I need to leave the seat bottom cushions out for helmet clearance on track days would like to avoid that. Also would like to retain sliders but if I had to would give them up.
Bill:
These may not be the greatest shots.. but they're all I have
![](http://forums.rennlist.com/upload/cockpit_2_copy1.jpg)
![](http://forums.rennlist.com/upload/seat_back_brace.jpg)
I'm 5'11 and have the SPG XL seats. I have recaro sliders and side mounts. The seat is bolted to the lowest front position and second from bottom position in the rear (if that makes sense). The angle that the shoulder straps take from your shoulder to the bar should not be more than 20 degrees from parallel, otherwise you'll have excessive compression on an impact.
I believe that the pole position seats have the shoulder harness holes placed somewhat differently than the SPG XLs, which IFRC are bigger and higher.
BTW, I purchased my SPG XL's this time last year... I'm contemplating going to a head restraint seat... so if you are interested in one of my seats, shoot me a PM and we can discuss.
Bill:
I can confirm that. 6'2" long torso. Belt holes were a couple of inches below my shoulders. I went with the gt3 seats with the big holes for just that reason.
The seat belt holes location realtive to the bar also depends upon how the seat is mounted. I mounted my PP to the floor with the bk plates and I believe the belt holes were below the DAS bar.
No pics. Sorry.
Pete
No pics. Sorry.
Pete
Bill, we are more or less the same size but with a longish torso relative to my legs. I run Pole Positions but with a BK harness bar. The harness holes on the PP's just barely are right for that set up. I would imagine that the harness bar crosses behind the seats at basically the same height as a roll bar. In regards to helmet clearance issues it hasn't been a problem with the Recaro sliders and side mounts and the seat is mounted a little bit below the lowest mounting points (I drilled them). I also run eye bolts for a clip in harness and have no seat clearance issues with them.
Thanks! Is the avatar big enough now?
Bill, I am 6-5 and have Profi XL currently. Previouly I had PP, the Profi XL has a taller back and larger openings for the shoulder harness. I don't have my DAS bar anymore, but with my Heigo bar everything is fine. I use BK seat mounts, can't remember the number but I can get it for you. With these mounts, slightly modified I could clear the headliner with my helmet on when I had a sunroof.
5'11" No Problem with the curve in the roll bar. The belt will work its way to the outside but you cannot tell when wearing it. I also use a Hans Device without issue.
