Installed a Lift Master
I finally have some flexibility in my garage. Due to my ceiling height and the use of a chain drive opener, I've had to store my SC over top of the C4S. Something about the shape of the Targa versus the Coupe only allowed the Targa to be on top. Today, I had a LiftMaster opener installed and I now have a full foot of extra space on top. The door is even lighter because the direct drive jack shaft opener doesn't require the extra door panel on top to pull.
Now I can put the SC on the bottom and the C4S on top so I can drive it more frequently and give the C4S a rest. It even lifts up high enough now to park my BMW. The unit is very quiet and comes with lots of features to boot.
Here's a shot of the old setup and of the new Lift Master. I'll see how well the unit works over time, but today at least it's great.
The unit even comes with a dead bolt lock that works automatically.
That is exactly the set-up I am looking for!! When you have a second, what is the height from the floor to the ceiling? I have a lowered Volvo V70R wagon that I would put underneath the 993 and I think this set-up would accomodate both assuming the ceiling height is the similar to my garage.
Thanks.
JH
Thanks.
JH
Thanks.
JH
Thanks.
JH
I just ordered one with my new garage build. I had never heard of them until recently. They are a great space saver and a must if you have a vaulted ceiling. I think it was only $200 more over the std Chamberlain 1/2 hp. I will now have 11' clear which should allow the lift to go to the max height. I'm deferring any under car maintenance until the lift is ready to go. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Does yours have the automatic electric locking mechanism? I hear this is required on these types of openers. I didn't ask if that was included as std with the Liftmaster but I think it is.
That is a cool idea! My opener is a bit in the way when I lift a 911 on my two post lift, I was just thinking of moving the opener over, but if it fails this looks like a great solution!
Thanks for posting!
Cheers,
Mike
Thanks for posting!
Cheers,
Mike
These (the openers) are great solutions - had two put into my garage. The jack shaft openers are the same concept as the industrial kind and for years they weren't out because of the lack of safety sensors (you know, kids and the like...) - but finally, finally, they've come around.
Nice garage man.
Nice garage man.
