993 Forum 1995-1998
Dash Question
Old Aug 13, 2008 | 01:32 AM
Flatsixer's Avatar
Flatsixer
Default Dash Question
I have a 1995 C2 Cabriolet with just over 19,000 miles and my dash has two bumps on the passenger side that drive me crazy. The car has always been garage kept and is a fair weather car that does not sit for long periods out in the sun. My 1990 964 had this same problem, what is the dash made of under the vinyl/leather and why do they warp like this ? I can still purchase a new dash from Porsche for a mere $2300 but the thought of removing my original windshield to replace it has turned me off doing it. Any fixes out there other than a new dash ?
Old Aug 13, 2008 | 02:19 AM
BobbyT's Avatar
BobbyT
Hi Flatsixer,
I think the dash on a 993 comes out pretty easy, no need to remove the windshield. Just take off the defroster trim between the dash and windshield, then remove a few screws (including one inside the center AC vent), and lift it off. I haven't removed one, but maybe someone who has will chime in.
Old Aug 13, 2008 | 05:34 AM
C4 NLW's Avatar
C4 NLW
The top dash cover is very easy to remove.
Remove the long plastic cover that runs along the base of the windscreen, from memory there are 5 screws. I believe there are two additional screws under this panel that need to be removed.
At the two ends of the dashboard on the side part that faces the door there are two plastic plates that are friction fit and simply pry out, underneath there are two screws to remove.
Finally there is a nut behind the centre of the dash that holds the dash cover in place. You need to remove the guage closest to the centre of the dashboard. With the guage out feel behend the dash and you will find one nut to be removed.
After that the dashboard lifts off.
All from memory so apologies if I left something out.
Old Aug 13, 2008 | 11:43 AM
titleist1's Avatar
titleist1
I have a like new dash available, had mine changed out for full leather version, easy to remove dash yourself, make me offer, thanks
Old Aug 13, 2008 | 12:33 PM
Stealth 993's Avatar
Stealth 993
Have you taken it to a local shop & see if they can fix it? Or just get it covered in Leather!!
Old Aug 13, 2008 | 07:02 PM
BufordTJ's Avatar
BufordTJ
Default W/S install and Dash removal.
http://s180.photobucket.com/albums/x...t=f198834b.pbw
This might help.
Old Aug 13, 2008 | 09:19 PM
titleist1's Avatar
titleist1
Default dash
I will sell it for $400.00, plus shipping, thanks for interest, James Graham
Old Aug 14, 2008 | 01:42 AM
Boston911fan's Avatar
Boston911fan
Good luck with your dash.
Titleist1, where did you get your leather dash? That is something I would LOVE to have!
Old Aug 14, 2008 | 02:54 AM
Flatsixer's Avatar
Flatsixer
Thanks for all the replies. I am glad to know the dash removal is less tedious than I thought, particularly knowing the windshield does not have to come out.
