Help Needed: Sunfroof won't close and it looks like it's going to rain.
Hi everyone,
For the last couple of weeks my sunroof has worked only when it wants to. In other words, I would open the sunroof and when I went to close it, sometimes it would close (perfectly) other times, nothing.
Well, the wife and I just came back from a long drive, dinner, etc. etc. When I pulled into the driveway, the sunroof decided it didn't want to close. I know the fuse isn't the issue because sometimes it works and sometimes it doesn't.
Any thoughts?
My problem is I'm up at my place in Maine and I have no garage here. Weather is 40% chance of rain. I know I can close it manually, but trying to avoid that at all costs.
Just wondering if anyone has run into this and if so, what the issue is.
Thanks,
John
Any thoughts?
Thanks,
John
This happened to me up in VT a month ago. I shut the car down and restarted after checking the fuse...while sitting in the car I banged on the roof at the back of the sunroof and then it worked. Beats having to do it manually. I'm sorry it is not very scientific but it has worked ever since.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I think you can wind it shut manually with the hand crank in your tool kit. Check the manual first, in other words, dont trust my bad memory
You definitely can do that, but i"m trying to avoid. Also trying to figure out what the issue might be.
Anyone know if there is a relay at the switch that I might need to replace? No noise from the motor. when it does work, it works perfect. Never an issue opening, only closing.
John
The "Fonzy" method. I'll give it a try. Is that your car as your avatar? is that Metallic Green or Black?
the "FONZY" method worked. I had tried restarting the car a number of times to no avail. This time, I started, tried (didn't work.) Shut it down, restarted, gave it a couple of good hard whacks around the mechanism and presto. Sunroof is closed!!!
Question, anyone have any idea what the root cause is? Would like to fix/reconcile if I can.
Thanks,
John
John,
Glad the "Fonzy" method worked. Interestingly, the manual states not to drive over 62mph with the sunroof open because this may damage the sunroof mechanism and/or headliner. While heading up to Stowe, I was driving above 62mph for an extended time with the sunroof open...oops but it was fun. Thats all I know. Yes thats my car and mug in the avatar...black cuz they are the fastest!
Loose or dirty electrical connector --One of the root causes of many electrical "gremlins". Unplug & replug a few times or scrape the connector pins/contacts gently to remove oxidation on the contact.
Stuck electric motor---I've seen motors stop in a position where they don't want to restart...
I'd vote for #1 most likely. Getting to the motor & bits isn't hard....one zipper and a screwdriver....5 minutes.
Good luck.
Good clarification. I was just sitting here thinking "Damn, I've been driving around with the sunroof open doing 80+ all this time. Wonder what I screwed up!"
Just to clarify ... the manual says not to operate the sunroof over 62mph.
