Help with Track Tires: Yoko A048 vs. MPS-PS2
I have come to realize that my Pirelli P-Zero suck as track tires so I am looking at better dual use DE / street tire. I am avoiding a true Dot-R like the MPSC and hoosier's.
I am down to the Yoko Advan A048 and the MPS-PS2. I have gotten over the initial shock of the price so I can move on.
I have a C4S so the PS2's don't come in the OE size, so I would have to run 225's /295's which it sounds like it's not really a problem. There is some debate with an AWD drive car and running 235's in the front. The cost is the other issue.
For the Yoko A048's they do come in my OE size. I hear they are loud compared to others. Not really a big deal to me, I am well past a comfortable car.
To me it seems the PS2 is more of a true mixed use tire with the A048's more of a sticky track tire.
Any input would be great.
Thanks,
Thanks,
Why do I feel so left out!
Jim,
Just MHO - but both the PS2 and the A048 are NOT track tyres....
Sticky road tyres = yes, but tracktyres = No.
Radials (both PS2 and AO48) are not designed to run hot and their curve falls off as the tyre gets hotter as opposed to R-Spec which work similar to slicks.
Not knowing exactly what you are looking for - the best advice I can give is to buy a 2nd set of wheels and fit R-Specs to those and keep a set for the street. With a bit of practice you can change Wheels in about 10 mins start to finish.
best,
Simon.
best,
Simon.
Platinum Dealership
I run the yoko's on my 993 turbo, and I like them- a lot more grip than the ps2...
they're a harder compound and even with a few heat cycles at the track they don't wear out at all on the road...I like them and would recommend them if you're looking for mixed use with long wear being a factor. I've never run them in the wet on the track- only on the freeway and stuff in the rain and haven't had any issues.
I recently bought PS2s for my C4S, but haven't mounted them yet. I went with 235/295. I looked into the AWD issue and compared overall diameter of the old 225/285 PS with the various sizes of PS2. I think (and hope) that 235/295 is the right combo of a 4S.
I think the overall diameter is very close if you compare the two. The number 25 comes to mind as the diameter. I think the arguement with the 225 vs 235 is turn in. some people like the smaller tire for this. On the other side you have 235's pulling with an awd car. Still probably not a big deal.
Jim,
best,
Simon.
best,
Simon.
As many opinions as people I gues, but here's my 2c. On my 2wd 993, i haven't found a better tire then the PS2. I do use PSC for on the track but use the PS2 every now and then if I don't feel like swapping the tires. imho the ps2 is the only real dual compound tire for street use. Giving extraordinary grip cornering and maintaining low wear when driving highway.
H
H
Still plays with cars.
The A048 is an R compound tire whereas the PS2 is a street compound. If you are looking for a sticky R compound then I suggest the Michelin Pilot Sport Cup, the Toyo Ra1 or the newer R888. If you have separate track wheels then the Hoosier R6 or the BFG R1 kick ***. The drawback on the latter two is that you won't drive to the track on them. The Toyos have more grip than the yokes and can be driven to and from the track. The Michelin Cup are ok on the street unless it is raining. The A048 is noisy as heck and not as grippy as the others I mentioned.
Best,
Best,
Best,
Best,
Former Vendor
If looking for the best tire to use dual purpose and expect to have any kind of wet weather traction (just in case) I think the Michelin Sport Cup is the most competent. PS2's are good but won't grip as well when hot. Have you looked at the Yokohama AD07? It's a street tire, but dry hot grip is very close to that of the Sport Cup and better than the PS2. That may be the best tradeoff of road and track grip that you are looking for.
As for size, try to stay within 4% OD. 235/40 and 295/35 is 2.75%, so OK. Don't run a 225 with a 295, especially with AWD. 235/40 and 295/30 is a great combo and only 1.6% different.
Call me if I can help further. Thanks.
