993 Forum 1995-1998
Alignment settings for track/street use?
Old Mar 5, 2008 | 03:05 PM
993turboplease's Avatar
993turboplease
Default Alignment settings for track/street use?
Installing PSS10's tomorrow, TRG sways, RS drop links.
I'm 50% track and 50% street; maybe 10 DE's this year.
I have Michelin PS Cups which I would appreciate if they would last through next season also!
Anyone know alignment specs for a 50/50 track and street mix - thanks in advance.
Old Mar 5, 2008 | 04:17 PM
Stealth 993's Avatar
Stealth 993
Go RS specs, & maybe 0 toe in the front & as much caster as you can run.
Old Mar 5, 2008 | 06:31 PM
Mark in Baltimore's Avatar
Mark in Baltimore
What run group are you in? How many track days do you have under your belt? How hard you drive will determine the settings you need. Even then, the settings will be a compromise for either street or track, no question.
Old Mar 5, 2008 | 09:38 PM
993turboplease
I've done about 10 track days starting last year. This year I'm running the 993 and also I'm going to try 2 stroke Karting. I push hard enough to spin at about half the trackdays. Which either means I'm pushing hard or I'm not a very good driver, probably the latter. I'm hoping to take the advanced driver class and some further instruction this year.
What are the factory specs and what are the track specs? Thanks.
Old Mar 5, 2008 | 10:11 PM
Greg H.'s Avatar
Greg H.
I'm at about 50% track and am maxed out front and rear -1.9 ish. I'd like to try more in front but that would involve mono *****.
Greg H.
Old Mar 5, 2008 | 10:15 PM
Mark in Baltimore
I think RS settings should be a good place for you to start. Dial in more negative camber settings if you're wearing out the outside edges of your tires. If you do this, street driving will wear out the inside edges.
Old Mar 6, 2008 | 12:12 AM
Wilder's Avatar
Wilder
Do you have a turbo? If so, I agree with Stealth, 0 toe, as much caster as possible AND go -2F and -1.75R camber. More camber in the front makes AWD cars fairly neutral. Also, watch your tire pressures.
Old Mar 6, 2008 | 09:46 AM
North Coast Cab's Avatar
North Coast Cab
What are the RS alignment spec's?
Old Mar 6, 2008 | 10:16 AM
Bill Verburg's Avatar
Bill Verburg
RS Spec for both M002/M003
front height 124+/-10
rear height 107+/-10
front
toe(unpresssed) +5'+/-5'
camber -1*+/-10'
caster 5*20' +15' -30'
rear
toe +15'+/-5'
camber -1*20'+/-10'
Old Mar 6, 2008 | 10:24 AM
Paul902's Avatar
Paul902
I'm at RS height +5mm, and RS alignment specs. After about 10 DE days and maybe 8000 street km my wear is fairly even across the treads, but the rear outside edges are starting to take a beating. I may need a bit more neg in the rear, but agree RS spec is a good place to start for a dual use car.
Old Mar 6, 2008 | 11:33 AM
993turboplease
RS Specs it is - thanks everyone
Old Apr 20, 2009 | 05:07 PM
onefstm's Avatar
onefstm
Can someone give me an inch conversion for the RS toe settings?
front
camber -1*+/-10'
rear
toe +15'+/-5'
camber -1*20'+/-10'
Old Apr 20, 2009 | 05:17 PM
Edward's Avatar
Edward
Addicted Specialist
Hi Jeremy,
FWIW, I went with a bit more negative camber than RS setting: around -1.2 degrees front/ -1.7 degrees rear. This worked very well with my PSS9s and 22mm/21mm sways both TimeTrialing and daily driving. It has now been a few years and several tire changes since I have tracked my 993, but still a daily commuter. Tire wear is still excellent and the car always feels secure as well as confidently planted on the street (not at all darty). If you spend as much as 50% on the track, I'd go with more neg camber than RS ...IMHO anyway
Edward
Old Apr 20, 2009 | 06:39 PM
Bill Verburg
Need to know the wheel size, 17, 18?
Old Apr 20, 2009 | 06:47 PM
Bill Verburg
Originally Posted by Edward
Hi Jeremy,
Edward
That's about right, most tracked cars will want close to 0 toe, and -1.5 > -3.0 camber in front(more -camber for slicks less for street tires) and in back a little less camber and a little toe in but tires and usage and other variables make each one a little different.
