the 90,000 mile service
Hi all,
Well, my little Red finally had her 90,000 mile birthday and at first blush, she still seems to be running strong ( Likes drinking a quart every 1000 or so miles). I'm still rather new to the 993 C4, but me being somewhat handy with a wrench (and also being able-bodied to move around now since my illness), I was wondering what the 90,000 mile service entails, and if it is feasible to do at home.
Also, if it isn't totally feasible, how much about does this maintenance cost?
Hope you are all doing well. I haven't posted much here since I got ill last March. But on the eve of the one year annivesary of my illness, I have some good news to share with you all - I got the doctor to sign off on my ability to drive a car again. So now, I'm still limited to literally driving to the corner store and back, but still being able to drive (and a Porsche at that)- that is happiness.
Cheers!
Cheers!
Hi saphriel,
I'm afraid I haven't got any advice re service , my wrench manners aren't all that civilised , but your post has touched me to post back.
fantastic news that you're back in the driving seat and that lil red is pulling strong , I hope you'll soon be driving much further afield than the corner shop ..
Sorry for the OT reply .... On with the thread!
Since you are local, give a call to Redmond Euro!
18014 Redmond Way Suite C-25
Redmond, WA 98052
425-376-2655
They are a great shop, & work on both my 993's!
I believe the 90k is just all fluids, filters, belts, plugs Cap & rotor, & lubing & checking a bunch of things.
Glad you got the Ok to drive, not sure I could do that!
Redmond, WA 98052
425-376-2655
I think there are many who do their own services on these cars; it all depends on just how handy with a wrench you are. As far as what's entailed in a 90K service, a comprehensive check list of exactly what needs to be performed can be found if you do a search on it. Good luck and congratulations on your improved health.
I believe the 90k, is the same as the 30k, and 60k, i.e., Major Service.
Glad to hear you are feeling better:
15K / 30K service and costs
Every 15K miles/24K km:
Change engine oil
Diagnosis system: read out fault memory
Anti-pollen filter: replace filter element
Oils and fluids: visual inspection for leaks
Crankcase ventilation: check tightness of hose connections
Fuel system: visual inspection for damages, clearance and tightness of line connections
Intake air: check hoses, lines and connections for tightness
Parking brake: check free travel of parking-brake lever
Brake hoses and lines: visual inspection for clearance, damage and corrosion
Brake fluid: check level
Brake system: visual inspection of brake pads and discs to check for wear
Clutch: check play or final position of clutch pedal
Throttle linkage: check for smooth movement and full throttle opening [this one gets inspected every time the car is driven, right?]
Resonance flap and Varioram: check operation (Carrera only)
Steering gear: visual inpection of the bellows for damage
Tie rods: check play and dust caps
Power assisted steering/clutch: check fluid levels
Ball joints: visual inspection of dust caps for damage, check tightness of wheel alignment adjustment/mounting bolts
Manual transmission/axle drives: check oil level
Automatic transmission: check fluid level
Drive shafts: visual inspection of boots for leaks and damage
Exhaust system: visual instpection for leaks and damage, check tightness
Tires: check condition and correct tire pressure
Door hinges: lubricate
Door locks, hood locks and safety hook on front hood: check for tightness and operation
Safety belt: check operation and condition
Seals for doors, hood and roof: remove rubber residue from body seal contact areas, apply suitable lubricant
Vehicle lights: check operation
All headlights: check setting
Horn: check operation
Windshield washer, headlight washer: check fluid level, nozzle aim and washer fluid freeze protection level for the winter season and whcih wiper system operation
All other electrical equipment as well as indicator and warning lights: check operation
During road or dynamometer test:
Brake pedal, parking brake, clutch, automatic speed control, steering, heating, air conditioner and instruments: check operation
Additional service every 30K miles/48K km:
V-belt and Polyrib belt: check condition and tension
Replace spark plugs
Air filter: replace filter element
Replace both engine oil filters
Automatic transmission: change ATF and ATF filter
Drive belt for power steering pump: check condition
Additional service every 60K miles/96K km:
Manual transmission and axle drives: change oil
Automatic transmission: change oil in differential
The manual also recommends brake system and airbag system maintenance every two years.
Source: http://www.993faq.com/archives/cat_m...ce.html#000185
Change engine oil
Replace spark plugs
SAI Check valve replacement.doc
Mine at 60K was so frozen/rusted in that we had to remove fixture that it screws into, but that assembly in a vise and add some heat to break it loose.
When are the caps and rotors inspected ? My car had the 60k service done recently and when i changed my dizzy belt 3k's later it did not look like the caps and rotors had been inspected (and they had certainly not been changed). The caps looked as they had seen their best days, so i put in some new ones .
