AC Jack Stands No Longer Available
Super Moderator
Needs More Cowbell
Needs More Cowbell
IIRC, UltimateGarage organized a group buy here on Rennlist a while back.
Perhaps contact them and see if they have any inventory?
http://www.ultimategarage.com/shop/p...4324c479d42555
GT3 player par excellence
they no longer have AC in stock. but they do have something similiar that he will post on his site soon.
Sears has something that looks a little more stable with an "integrated" jack
http://www.sears.com/shc/s/p_10153_1...Lift+Equipment
Noodle Jr.
I just like the idea of throwing them under the car and raising from there. I need to measure to see how high my jack points are but still it looks simple. You can get different heights also.
I don't know about those. The base is rather narrow and the lift height is only 4 inches (9 2/5 to 13 2/5)
And why is the flat top jack stand such an elusive beast?
Hey Chuck... this is my thread... don't I get first dibs, especially since I'm local in Philly and can pick them up this weekend. PM sent.
In the fall, when I could not find the flat top stands, I bought 1/4" thick steel 3" diameter steel disks and took the "U" shaped stands to a welder. They cut the "U" off and welded the disk on. They then drilled and tapped the shaft with new disk assembly for a large stainless steel cap bolt. I then took a hockey puck which is exactly 3" and froze it (tip thanks to a R'Lister) and then in a drill press drilled a blind hole. The puck locks to the stand via the cap bolt insertion. What is nice is that I can pull off the puck if necessary and have a steel base.
Very simple- $50 bucks at the welder, a couple of pucks and cap bolts.....
Sorry, no pics- they are packed up.
