Anyone know of somewhere that makes alum drivers floorboard?
Make you own, you just need to make a couple of carboard templates and then cut a couuple of sheets of 2'x2' aluminum(choose your thickness)
Don Plumley did A nice writeup over on Pelican 964/993 when he made his.
http://www.rennline.com/prodinfo.asp?number=TM05FR
Get the race floor boards, not the aluminum "floor mats".
I installed Rennline's in my track car (driver side only). Highly recommended.
I wanted mine because the wiring harness was exposed and lay right under my right foot as I climbed in through the cage. Stepping on the harness each time was asking for trouble.
I didn't buy the passenger side as the fire bottle is bolted to the floor on that side and because there is no wiring to protect.
I have the whole Rennline kit in the C4S, the peddles, & floorboards. Everything fit perfect, & looks awesome! I can also put the floor mat on top of the race mat.
Just wonder how the Track Mat mounts to the floor and is there an opening where the bolt comes up in front of the seat and is that the mounting point?
