What's a good, cost effective, OBDII-diagnostic scanner?
I hate being in the dark with regards to what the codes mean so, I need to start looking in to getting one of these gadgets. Are some more user friendly, better value for the money, do more than others (like reset codes) etc?
I bought the Harbor Freight cheapie for $40.
It reads, resets, etc. but not the most intuitive menu system. I think something was lost in the translation from Chinese to English. Anyhow, it does the job but I am sure there are better out there.
Get one that gives the code #'s AND the read-out text. Some only give the code #'s. A good sale price is $100 to $120. If you do a search on this forum, you might find a source for under $100.
I have the Innova Equus 3130: it is capable of more than I will ever likely use, but is dead simple in operation, priced ~$125
Whatever you get ... if the word gets out, more pals will be dropping by: I've read and cleared codes on over a dozen different vehicles recently
As far as reading 993 codes, works great! .... codes plus text descriptive.
If I did it again I'd spend a few more $ for the better one.
I've had two: The Autoenginuity PC based scanner and now an Actron 9180. The PC based device was cool, but taking the laptop out to the track, waiting for it to boot, then connecting with the car was slow. The Actron gives me all the information (freeze frame sensor data) but is easier/faster to use. Less than $100 too. The basic Actron 9125 is only $40 at Amazon - that's a deal.
Anyway, this one works ... and here is a reasonable deal, and product data on this fleabay auction.
EDIT: had I known what I was doing at the time, I would have followed the good advice in posts 6 & 13 ( Geoff & Jason) in this thread ... for it takes one beyond the DME; however, for simple code reading and resetting CEL's, there are many reasonable choices.
Duramatic was the name I was searching for - but it is $$$ and the only user report via 'search' was negative.
I'm looking at the Durametric enthusiasts package. I have a similar system for my VW Diesel so I'm quite familiar with how it operates. I like the laptop connection better then a simple scan tool. You have more options and it's generally better explained on what's going on.
I might not have spend enough time looking around but it seems like they know what they're talking about.
Super Duper Moderator
I bought the Actron 9125 from Amazon for $39.99 as referenced above. Got it yesterday, plugged it in and 2 minutes later I had mode code read and cleared. Can't go wronmg if that is all your after.
Now I need to find a new gas cap for my Tahoe.
