Oil Leak After Change??? NOW WITH PIX!!!!!!!!!!
#31
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Order a new o-ring that resides near the tip of the drain plugs as well. This will make the quick swap much easier. Of course, a new crush washer as well.
#32
If you do remove the plug make sure you are in a "splash" zone. I tried this once, the oil really rushes out the hole so the oil will spray in all kinds of weird angles when you open the drain. You have a few options:
1 - Just go for it but I bet you will lose 1/3 to 1/2 of the tank and the floor will be covered, nevermind yourself OR
2 - Dump the oil in an very clean container. Preclean the pan with brake cleaner and make sure its really good, then dump the oil and put it back into the engine OR
3 - Just go ahead and dump the oil, replace the plug at your leisure, and fill with new oil. The safest and easiest method. Get the shop to pay for the oil and plug if you can. If not at least you have the piece of mind you did an "oil flush" and have a new plug OR
4 - Like you suggested, just drive to the shop and get them to fix it. Easiest option in many ways.
The big question is of course how tight is that plug...is it overtightened?
Cheers,
Mike
Cheers,
Mike
#33
Noodle Jr.
Took it back yesterday and they put in a new drain plug and reused the oil that came out. They did not over tighten the plug when I checked it so it just failed. They didn't charge me anything and were very apologetic even though it wasn't really their fault. BTW the oill change was just under $150. European Import Maintenance Center in Harrisburg, PA.
#35
Serves you right for letting someone else change your oil. You KNOW 100% that would not have happened had you done it yourself. I've seen this exact same problem on a buddy's 993 that he'd last had an oil change on with the local dealer. They are used an air gun on it and broke off the lip. Of course, they just left it on, figuring no one would notice until the next oil change. No reason whatsoever to use air tools on any part of an oil change other than R&R'ing wheels.
#36
Noodle Jr.
#37
I think you could also do the same damage with an air gun upon loosening it. I've worked with an air gun set to 1000 ft./lbs. before, and it darn near shattered a wheel lug with just a touch of the trigger.
#38
amazing the DIY prat falls I'll create for myself...I forgot the crush ring during the last oil change. To reinstall, I had my son on standby to reattach the ring onto the plug while I did my best impression of the little boy holding his finger in the dike..didn't loose but a 1/8 of a quarter of oil...learned my lesson...again
