Found out why my engine was down on power. You gotta see this.
I think Jason is onto something here,....
For the past 12 years and better than a hundred cars, we have used the stock aircleaner cover and carefully cut away most of the center, leaving a rigid frame (using OEM paper element, of course) with no issues whatsoever.
JMHO, of course.
JMHO, of course.
Technical Guru
My first post warning about this (that I could find) goes back to 2004. I help a few other 964 and 993 owners with servicing their cars and noticed the same problem on the other 964s but it wasn't until last October that I had enough independent evidence to start a thread with photos (linked to in my previous post). The problem with the 964 cover is that you don't really notice the problem unless you're looking at it from the rear of the engine, and most people don't drop their own engines. The 993 cover is basically (for the most part) the same piece as the 964 cover so the situation is the same. If the 993 part has the same problems (which appears to be the case from Eric's 993) hopefully we'll have some more photos to document the problem and warn people.
Seared
Technical Guru
Absolutely! The dremeled cover will still fit properly and the stiffening ribs will prevent it from warping.
Glad that you figured it out and that it wasn't something more major.
I'd recommend AGAINST the K&N filter as several people have had issues with the oil used to lubricate the filter can cause the filament/sensor on the MAF to fail, and thus cause the engine to hunt.
RL Technical Advisor
I met a guy this week at my BMW dealer. He was having trouble with his engine while using a K&N filter. The "stealer" change the "flowmeter" and charged him $$$! I explained him what my thoughts were, being not sure that we can clean the sensor if it's oiled.
Two bad experiences with the Fabspeed cover here. Both were gifts from other people who noticed the problem, figured I'd take it off their hands and be more successful getting them to work right. Never did.
I fitted, refitted, and refitted again to make sure the cover and filter were properly aligned. No luck, the filter always collapsed inward.
So I did as Steve W suggested, I took a stock lid and carved away most of it.
Biggest benefit to cutting your own is that you can leave enough to better protect the filter from water spray.
JMHO, of course.
JMHO, of course.
