IS this Normal? HID
IS this Normal? HID
I need to run the engine for the HID light to come on? If I just turn the ignition a bit to get power, the light is either weak or doesn't come on (sometimes)?
Does the ballast needs the extar power?
TIA
TIA
It's normal to get the flicker when you first switch them on. The flicker goes like this: bright flash, lights go dimmer than normal, and then over the course of about 5 seconds they warm up to full brightness.
That's what my driver's side was doing before the ballast went completely out and I replaced it. If it's both sides, I can't imagine both ballasts going bad at the same time.
Cheap as the kits are, I would buy a whole 'nother kit. So you have some spares.
R.I.P
I believe that I have had HID's about as long as you have (not very long). I have had that happen on occasion. I believe that it is because my battery was run down. I run 2 amps for my audio system and it is just about always on, especially when working on the car.
