993 Forum 1995-1998
Dang - my new ballast resistor did not help oil cooling...
Old 10-09-2007, 10:11 PM
Marlon
Marlon's Avatar
Unhappy Dang - my new ballast resistor did not help oil cooling...
Well - completed a nice, tidy oil cooler ballast resistor change and the cooler fan still does not work. Relay ok (swapped with it's sister relay) and fuze ok (visually checked). Cooler is nice and HOT so it is getting oil. Temp needle will go to 10:00 or so idling in the garage, but if I drive it, it will go down to 9:00. Any ideas? In order to check the electrical connection at the cooler fan motor, does the connection simply pull apart or do you have to squeeze some fittings to allow it to come apart. I can't really get my head in there to tell by observing it from the fender lip.
Old 10-09-2007, 10:37 PM
jimbo3
jimbo3's Avatar
I'm not familiar with the connections, but would you be able to run 12 volts directly to the fan to test to make sure that it's not the fan that died? No sense in replacing everything along the path if the fan no workie!
Old 10-09-2007, 10:54 PM
NP993
NP993's Avatar
The DIY on p-car.com has instructions for jumpering the relay to get the fan to run.
Old 10-09-2007, 11:34 PM
rwestervelt
rwestervelt's Avatar
You can remove the passenger side headlight and unplug the oil temperture sender. (I tied the wire and connector up so it did not get caught in the fan.)
Then switch the ignition on and wait for 60 seconds. The fan should come on. I ran mine this way for several weeks until I installed the override switch.
Old 10-09-2007, 11:52 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Did you bypass the relay as outlined on p-car.com?
Old 10-10-2007, 09:06 AM
Ed Burdell
Ed Burdell's Avatar
Originally Posted by Marlon
...I'm almost tempted to leave the plug out and run the fan high all the time - for now...
That's how I've been running for a year and a half now. I have peace of mind now whenever I get caught in traffic on a hot Atlanta day that I won't cook my engine.
Even with the fan running on high from the get-go, the oil gets up to temp without too much delay, which was the motive for the two speed fan in the first place, I believe.
Old 10-10-2007, 09:12 AM
Bill Verburg
Bill Verburg's Avatar
You could always install one of these and be done w/ it
Old 10-10-2007, 01:37 PM
Amfab
Amfab's Avatar
Marlon have you considered that the cooler is dirty and clogged? See https://rennlist.com/forums/showthre...ean+oil+cooler
Old 10-10-2007, 09:42 PM
DBYT
DBYT's Avatar
Had the same issue as you about 6 months ago and it turned out to be the oil temp sender. Now fixed.
Old 10-11-2007, 10:44 AM
chris walrod
Guru
Rennlist Small
Business Sponsor
Do you still have the black car? If so, maybe you can swap CCU's to see if the problem follows the CCU or not??
Old 10-11-2007, 10:57 AM
rwestervelt
Given the fact that the balast resistor is new and you can jumper the relay so the fan runs at high and low speed, the temperature sender seems like the mostly likely culprit.
Old 10-11-2007, 11:00 AM
Rick Lee
Rick Lee's Avatar
Subscribing.
Old 10-11-2007, 12:15 PM
ppressle
ppressle's Avatar
Are you sure it is broken? My low speed fan does not come on until somewhere just before 10:00. Looking at the pcar diagnostics, that seems to be the norm. Surprisingly warm. My justification is that they want the oil to get above 100c to boil out the moisture.
Is that not what other folks are seeing?
There was a thread where folks were talking about adding in a resistor in series with the sender to trick the ccu into turning the fan on sooner.
Pete
Old 10-11-2007, 12:17 PM
ppressle
ppressle's Avatar
Bill,
Which cooler is that? Cargraphic/Ruf?
It looks perfect.
Thanks,
Pete
Old 10-11-2007, 12:26 PM
Bill Verburg
Originally Posted by ppressle
Bill,
It looks perfect.
Thanks,
Pete
I bought it from Gert, they all buy from somewhere else, perhaps Porsche. The brackets bolt up to the AC condenser and swap the fan,
Quick Reply: Dang - my new ballast resistor did not help oil cooling...
