Why is my clutch fluid so filthy?
Or at least, why is it soooo much worse than that which came out of my brakes? I flushed everything today. ATE Blue was one year and about 5k miles old. Slave cylinder is two years old, but I always flush the clutch when I do the brakes. What came out of there today looked like used motor oil with a hint of blue. Why is it so bad?
I should clarify that the actual slave cyl. is two yrs. old, but the fluid was only one yr. old. Looks like I'll be doing this again in a few mos. I can't sleep at night knowing it looks like that.
Seared
Rick,
When I first flushed the slave cylinder, the crap that came out looked like ink. I am convinced that the fluid was original at almost 11 years old and 34,000 miles. Of course the flushing caused the slave seals to go bad which meant a new slave & hose, and yet another flush. Nearly two years later and the pedal action is still butter smooth.
I guess I should add that to my list for this winter!
Andreas
Andreas
Technical Guru
Seared
Rick,
A stainless-jacketed line would typically still have a rubber lining - although a few companies are now lining the insides with Teflon, etc.
When I went through my brake line replacement ordeal, the one company that was able to make the correct lines for me was Crown Performance in California. I bet you could send them your old rubber line and have them fashion a new one in stainless with the correct ends.
Andreas
Andreas
Andreas - here's a question: since teflon/stainless brake lines tend to firm up the brake pedal, wonder what would happen to the clutch pedal 'feel' with a less flexible soft line???
Originally Posted by JasonAndreas
When you replaced the slave cylinder did you also replace the soft line? I've noticed that it only takes a few days (even without driving and separate to the normal moisture problems) for the soft rubber hydraulic clutch line to leech into the fluid and turn it black.
The clutch circuit on my '80 928 still bleeds the same light amber discolouration as the brake lines; however, my 993, an '86.5 928, and a 3.2 carrera I've done in recent weeks all bled filthy black from the clutch line. I'm sure that the latter two had never been touched in years .... and suspect the same of my C4S - which was delivered with a "fresh brake fluid change"
Seared
In the clutch circuit, you are merely pushing fluid with the clutch master to the clutch slave - but are only pushing as far as the pedal board stop allows. I would doubt any noticeable difference.
Andreas
Technical Guru
Originally Posted by Garth S
Could be .... but I had assumed that the rubber clutch hose was made of the same spec elastomer as the 4 brake hoses .... and they do not leach black if bled annually.
