993 Forum 1995-1998
Belts are for wimps!
Old Aug 12, 2007 | 11:38 AM
AOW162435's Avatar
AOW162435
Seared
Default Belts are for wimps!
After reading all of the recent threads (#1 #2 #3) about how the A/C belt robs valuable power, I decided to take it one step further. I went to the garage and simply cut the A/C, cooling fan, and alternator belts in half and tossed them in the trash. That left the power steering belt (who really needs power steering?). I had to get the car on jack stands in order to remove the cover over the power steering belt. Then it took a few seconds to saw through the belt with an old hacksaw blade. Put the cover back on, got the car back on four wheels and took it for a drive.
All I can say is, "WOW!" I think I easily gained 50 hp! I took it on a favorite loop and was floored at the power that I uncorked by eliminating these stupid belts. The steering was actually manageable, and the A/C is for poseurs anyway. A few miles into my shakedown cruise, the car died. I guess my battery was not strong enough to sustain the ignition. So I picked up a new battery and motored home.
I am so thrilled with this improvement and can easily justify a few batteries every month if it means freedom from the belts.
Andreas
Old Aug 12, 2007 | 11:45 AM
Svaha's Avatar
Svaha
Try sixth gear at 1200 rpm without those belts, a symphony of sound!
psychoideas's Avatar
psychoideas
You're just too funny!
Old Aug 12, 2007 | 11:49 AM
AOW162435's Avatar
AOW162435
Seared
I tried that and it sounded nice, but then I mashed the go pedal in third gear and found that the engine would easily spin to 7,500 rpm. It's just amazing how much power these stupid belts have cost us over the years.
I will try to organize a group buy on Interstate MTP-91 batteries.
Andreas
Old Aug 12, 2007 | 11:59 AM
jdistefa's Avatar
jdistefa
Did you take it to 142mph? Oh, and remove your seatbelts too, after all they weigh a lot. Every bit counts Andreas!
Old Aug 12, 2007 | 12:02 PM
cabrio993's Avatar
cabrio993
I did the same thing about a month ago and found that the oil temperature was always pegged at the 11pm position after 5 minutes of running it and then the engine would simply shut off.??? weird.
Maybe the engine tray is causing it to overheat? Or should I put back the fan belt on? or maybe the wide open throtle operation at 1500 RPMS could be the culprit?
But boy...for the few minutes that it runs before it shuts down, it feels very powerful!
Old Aug 12, 2007 | 12:07 PM
Garth S's Avatar
Garth S
Too kool! Could you write a TSB with pics on the correct cutting technique?
I wouldn't want to screw up by being 'half-cut'
Old Aug 12, 2007 | 12:13 PM
AOW162435's Avatar
AOW162435
Seared
I was able to hit 194 mph before the battery died. The power is just unreal!
I'll keep the seat belts for now, as they help contain my man-***** in the twisties.
Any cutting technique will do for the main belts, but the power steering belt requires a very deliberate sawing action.
If I could only figure out a way to remove those stupid steel belts in my tires.
Andreas
Old Aug 12, 2007 | 12:55 PM
MarkD's Avatar
MarkD
Andreas
yer killin' me...
Old Aug 12, 2007 | 12:59 PM
Cactus's Avatar
Cactus
Noodle Jr.
i think you are headed down the bunny slope!
Old Aug 12, 2007 | 01:03 PM
AOW162435's Avatar
AOW162435
Seared
Yep, and I'm doing it with all motor power!
Andreas
Old Aug 12, 2007 | 01:29 PM
Ed Burdell's Avatar
Ed Burdell
Just whatever you do, keep the belts of whiskey and/or tequila!
Old Aug 12, 2007 | 01:39 PM
diet97993's Avatar
diet97993
Hot damn!.... you may want to check your oil level ....sounds like you're a quart or two low today!! But free horse power is free horse power.........
Old Aug 12, 2007 | 02:30 PM
Amfab's Avatar
Amfab
Andreas, I updated the speaker dust thread, because there were some obvious issues that related directly to removing the belts.
https://rennlist.com/forums/993-forum/370110-speaker-dust-issues.html
Old Aug 12, 2007 | 02:39 PM
901aero's Avatar
901aero
Time to dispatch the hit squad from Stuttgart. Sorry Andreas.
