993 Noisy Spoiler Drive DIY
Last weekend I tackled a DIY repair on my noisy 993 spoiler drive. Using these instruction: http://p-car.com/diy/spoilerdrive/ I was able to easily determine the noise was coming from the spoiler drive worm gear. Following the instructions, it was a snap to disassemble the worm gear housing and locate the dried out bearing. The replacement bearing is a common one found at any bearing shop or on the internet. The reassembly was a breeze and a couple of hours later I tested the drive and was well pleased with the quiet operation. This is definately one of the most satisfying DIY's I have done on my 993. Give it a try!
Is this bearing something we should be lubricating every once in a while to help it last longer?
Renaud, you'll need a 16x5x5mm sealed bearing, often called 625-2RS or 625DD. I found mine on eBay.
Cheers,
Tore
Cheers,
Tore
https://rennlist.com/forums/993-foru...ml#post8431240
