993 Forum 1995-1998
Question: Tie-rod assembly left to right length difference
Old Aug 5, 2007 | 12:20 AM
Francisco Martinez's Avatar
Francisco Martinez
Default Question: Tie-rod assembly left to right length difference
I am in the process of replacing left and rigth tie-rod assemblies. After removing them I proceded to measure them inorder to adjust the new ones to the proper length and hence aviod having to redo alingment. There is close to a 4mm difference in length from one side to the other.
Is it normal to have this much difference between the tie-rod lengths? I feel inclined to just split the length in half and make both tie-rods the same length. The steering wheel will not be centered but that's an easy fix.
Old Aug 5, 2007 | 04:48 PM
GeoT3's Avatar
GeoT3
Francisco,
Do you have a 996 ( 3 spoke ) steering wheel installed on your 993? If so, that is your answer. The 996 steering wheel does not have the same mounting reference as with the 993 steering wheel.
George
Old Aug 6, 2007 | 12:50 AM
Francisco Martinez
I have a Momo Course Wheel which went into the same exact position as the original steering wheel.
Old Aug 6, 2007 | 07:41 AM
GeoT3's Avatar
GeoT3
You should have your car realigned if it bothers you. Toe adjustment should be done on the rack.
George
Old Aug 6, 2007 | 09:30 AM
Francisco Martinez
Thanks George..
Old Aug 6, 2007 | 02:04 PM
Garth S's Avatar
Garth S
I am just going through this issue, having replaced the steering rack: what I may suggest is that the total length of the rack plus two complete tie rod assemblies will be a constant for the correct toe-in once camber and castor are set.
Once that total length is known, the two rods are tweaked to cause the dimple on the rack rod to be centered in the bottom inspection window ( black plastic plug under the pinion spline) ie., shorten one rod as the other is lengthened.
With the dimple centered, the steering wheel should be dead flat horizontal .... if not, the wheel must be adjusted.
As you are only touching the tie rods, an accurate measure of toe-in can be made using two 2' levels with stand offs to avoid tire contact as they are pressed horizontal to the rim ... and a good steel tape to measure ahead and behind the wheel - difference being toe-in ( or toe-out if one screws up )
Otherwise, have it done on an alignment rack .... for counting turns on the rod ends is an approximation to the measure desired, and generally not sufficiently accurate.
Old Aug 6, 2007 | 04:59 PM
Francisco Martinez
Thanks Garth, that sound like a plan...if it does not work out I'll just take it to an alignment rack.
Old Aug 6, 2007 | 05:19 PM
Jack of Hearts's Avatar
Jack of Hearts
I don't think I'd make them the same length without a rack...4mm could easily be the tolerance in the cast pieces in the suspension and that will stay the same even if your rods are new.
Old Aug 6, 2007 | 08:09 PM
Francisco Martinez
Hey Jack,
My intention is to make both tie-rods the same length by following the procedure described by Garth (taking from one side and adding to the other) which would lead to the same side to side length.
