The expected BIG service bill
My car went in for the full once over. Here is the list of items:
60k Service $1465
Chain tensioner leak and cam cover leak $3175.00
Program new remote $75.00
They suggested replacing clutch and flushing SAI ports while engine is out but have yet to tell me what that will run. The flush should be cheap since the engine is out.
They gave brakes, steering and suspension a clean bill and stated that there are a lot of new parts recently put on the car (struts, rotors etc)
What do you think about these prices?
60k Service $1465
Why would they need to take the engine out for? Chain tensioner leak? I believe that some have replaced the seal without droping the engine. The main issue is the AC bracket that is in the way.
How bad is the leak? If not bad, I would wait until you really need to drop the engine for clutch, etc and do it then.
sounds like engine is already out. if so....definitely do clutch while it's down. research some clutch's...I'm sure you'll find a lot of input here.
"what do you think of these prices"... Chain tensioner leak and cam cover leak $3175.00 ... that one sounds high to me. but it probably includes dropping the engine if it's already out
I had my engine removed and torn down with the valve guides replaced and SAI passages cleared, 60k service performed, brakes flushed, and a new LWF and RS clutch installed, and Bilstein HDs and M030 springs installed, and the car aligned, for about what you're being asked to pay (I provided the parts for the suspension and clutch/flywheel), I think you can probably find a better deal ... is that a dealer price?
Hello,
Yep, thats dealer price. I have used them for my previous Porsche repairs/service and they always did right my me.
The labor for engine removal is built into the $3175 (2800 labor, $375 parts)
You're paying crazy dealer markup. This calls for an independent wrench, methinks.
74k on the car. I have owned it for a month so can't accurately rate how bad the leak is. I really trust Holberts and don't mind spending a little more over an indy shop I just don't want to be raped!
Andreas,
You got that right, they can program the remote for free. They also talked as if the SAI flush would likely be included as well.
Andreas,
I wouldn't own any cars if I ever had to pay a bill like that for so little work. ( I have six). Let the sucker leak until you find a real mechanic and not a high overhead sales outlet for new cars. Good luck.
Guy,
I don't own a 993, I have a 968 (but secretly lust after a 993 - honest!). I took '68 to Holbert's once (I live up in Plumsteadville, and work in Warminster). I won't take it there again. I take the 968 to an indy that specializes in the 4cyl variety. Won't help you much other than my feedback from direct experience with Holbert's. That said, I bought my Jetta there and get it serviced there - so far have been happy with VW service. Just not the Porsche. In my opinion, they are truly a typical "new car dealer" with regards to Porsche. They would rather work on newer cars and let the classics go elsewhere. My neighbor across the street got the runaround from them on his '79 911 as well.
There is a place near Philly called Dougherty's. Never been there and not really sure where it is exactly, but they apparently have a good rep. No affiliation whatsoever.
No matter what, good luck and your car is beautiful!!!
Originally Posted by Guy
.... I really trust Holberts and don't mind spending a little more over an indy shop I just don't want to be raped!
I just bought a new economy Chevy for our kids commuting. Yesterday I took the car in for a couple items that needed to be fixed under warranty. When I called the knowledgeable, personable service writer to see if it was done, he said it's just gone through the car wash and is all ready to go! I arrived, waited 15 minutes and the car appeared ... unwashed. Obviously that's not the norm but does illustrate how little the service writers actually know what goes on out back in the shop. Save your trust for a good independent mechanic who will actually work on the car or directly supervise the work.
