Dreaded CEL - CRAP!
#31
Unclespeed, we're in the same neighborhood. And your SAI issue, the only problem is the CEL annoyance. I haven't hit that problem with mine, but figure it will happen sooner or later. If you want to fix it, I'm willing to experiment on your car. And I'll offer my garage for it. Maybe we should discuss over a beer some night?
#32
ok.....so I had too many RL session/windows open and had actually not read the posts above mine....so ignore what I asked! I have decided to also check the vacuum hose and failing that, I will just drive her hard(er), try to do a few more track days.,..and pray![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
fyi...I have normal power and oil useage (~1quart/1k miles). previous owner did the DIY fix and it worked for 4 years/17k miles
I will save my money for now...and spend it on further mods
#35
Sorry to say, but that's not normal. Your valve guides are worn. You'll see that once you do the top end, your oil usage goes down to 0 quarts/1k miles. My car has 125K and had the top end done at 75K and in five years of ownership I've never added a drop of oil in between changes and the oil level never changes. That's how it's supposed to be.
#36
I would say its on the higher side, but you also need to compare driving conditions, etc. I have worked on cars that would get 800 miles/quart in the city, stop and go, have excellent compression/leakdown, and do over 1500 miles/quart on the highway. That car has been running that way for years. I have also seen cars that are like yours, very little oil consumption as well.
The trick is how to judge when you absolutely require the top end vs just putting oil in (which is much much cheaper). I think under normal driving use, you can push it to when secondary effects come into play, like fouling plugs, fouling the Cat, misfires, etc. If you are tracking the car, or really drive the car hard, then it's earlier since with excessive wear the heat is not transferred from the valves to the heads very well, and that can cause major failures.
Cheers,
Mike
Cheers,
Mike
