RS Battery Cutoff Parts
Has anyone added the RS battery cutoff to their 993. Any of the guys that have a real RS that has the cutoff care to share photo's of the interior and trunk install.
I am wanting to add a battery cutoff to my car and what to keep it looking original. I have seen the cutoff parts in the PET catalog but I have not seen one up close. I want to add the interior cutoff to the spot next to the headlight switch.
The big question I have is if it will kill the power completely and is it DME safe. I know that there is a newer kill switch that has the electronics and DME safe but I wanted to hear about the RS kit.
Standard RS, has the metal mounting plate, but no battery cut off fitted either under luggage lid or on the dash.......these were fitted to clubsport versions though,,,,,should be able to get some pics when I am next near the car unless details get posted before then
Thanks for the photo. So is it just a pull strip in the interior attached to the cutoff switch in the trunk. For some reason I thought the interior had a turn style switch as well.
Also, are there any DME related parts. I though there are issues with a live alternator and radio code resets if it's not isolated correctly.
Also, are there any DME related parts. I though there are issues with a live alternator and radio code resets if it's not isolated correctly.]
here's an article on installation
http://www.kitcarmag.com/howto/cutoff_switch_install/
Do you think you will actually be pulling the lever then??...I have never shut down the car this way while running, the only occasions I have turned the electrical cut out to "off" is when I have left the car for extended periods of time,,partly as a security measure...surely it is 90% image / 10% function ?
Originally Posted by jdistefa
Other option (non-OEM):
http://rennline.com/product.php/sid/...che/prodid/105
