Love my new PSS9 suspension, but . . .
I had my PSS9 suspension installed by a shop that works on many race cars - excellent shop. The handling is now incredible! The ride height appears to be just above RS and it's pretty cool sitting that much closer to the road.
But . . .
I was looking at the spacing of my front tires relative to the wheel-well. The drivers-side looks very close to the front of the wheel and is about an inch closer than the passenger-side. I haven't heard any noises when I go over bumps, this far.
Other than aesthetics (not centered within the wheel-well), is there any concern being somewhat close to the front of the wheel-well?
Is this an alignment setting (car was aligned and corner balanced)?
Gus
'95 993 C2 Blk (Built April '95)/PSS9s - previously M030/LSD/Michilin PS Ribs
But . . .
Gus
If you have that much difference I would venture to say that you have different negative camber between the 2 front wheels. It does not really matter if the wheel is centered or not, with negative camber the top will be more inwards than the bottom and you want that anyway, but having 2 different camber settings is not good at all...
Who did the alignement? Did you get a printout of what the values are?
If its strictly a street car RS specs which are -1 camber all around is a nice setup.
Should be the complete opposite in regards to the tire to fender issue. Maybe the shop didn't corner balance it with weight in the drivers seat. Or as Danny says different camber. Got any pics?
Just a wild guess here but did the shop give the car enough time/miles to let it "settle" before doing the alignment. I know when I did mine, after driving apx. 25 mi. it set diff. than it did right after I finished the work.
Thanks guys! I didn't get a chance to upload the photos I took. Also, after looking at them the difference seemed minor - perhaps too much of a perfectionist. In the meantime, I visited my shop and they took a look. They thought it is most likely due to a minor difference in the fender from side-to-side (no, the car has never been in an accident). He said the only thing that could affect that would be the caster as it could move the tire slightly forward/back.
The car handles exceptionally well, so I'll have to trust them. Thanks again for your feedback. I'll try and post a pic of my carr soon.
Originally Posted by Gus Sem
......The car handles exceptionally well, .......
That the best news: keep an eye on tire pressures and wear patterns to remain assured that all is well. A light finger drag across the tread in either direction can pick up assymetric wear that is nearly impossible to see ... were it to occur.
Enjoy your new suspension !!
