Rear Tires: MY95
Rear Tires: MY95
Any truth to MY95's eating rear tires at an increated rate relative to MY96 and above?
Originally Posted by Sean Spicer
Yes, until you have it aligned to 96+ specs.
sean
sean
Addicted Specialist
Specs smecks. The TTs eat rears at an alarming rate, but methinks that has more to do with, oh, something other than alignment
Get a good alignment from a good shop that KNOWS 993s. There is a window of alignment parameters you could go with, and remember there's no "one" perfect setting as it's all a compromise between tread life and road holding. And as Craig said, kinematic toe is important, especially for rear-suspension feel/solidity during cornering. FWIW, I can get 15-18K miles on rears, combo highway and aggressive street driving, but I also don't do burnouts or stoplight battles
Edward
Edward
Originally Posted by 97Targa
Be sure that the set the kinematic toe in correctly.
Any alignment shop will simply know to align your car according to '96+ specs, so there really should be nothing to worry about.
Addicted Specialist
LOL! And thanks for that correction, Eric. I "suspected" kinematic affected treadwear; thanks for clarifying. I will also be certain to check underwear periodically as this has been known to affect the butt dyno.
Edward
Edward
Originally Posted by Edward
LOL! And thanks for that correction, Eric. I "suspected" kinematic affected treadwear; thanks for clarifying....
