Mobil 1 15w-50 vs. 15w-50 Extended Life
Does it really matter if you use Mobil 1 15-50 vs. 15-50 EXTENDED LIFE ? I chance my oil ever 3k anyway. My thoughts are it cant hurt any.
You may want to reconsider using any version of Mobil 1 15W50 - they have reformulated it will far less wear protection to meet new regulations:
http://www.lnengineering.com/oil.html
Originally Posted by mstupp
There is quite a long discussion about the recent reformulation of oils over at Pelican.
http://forums.pelicanparts.com/showt...hreadid=332678
Can anyone put this into plain language? Mobile 1 good/bad?
I didn't think I was stupid but perhaps I should reconsider.
http://www.mobil1.com/USA-English/Mo...1_15W-50_.aspx
Alas, there maybe hope... The "new" 15-50, hopefully its the old formula...
From the site: "Mobil 1 15W-50 is also recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required for newer generation vehicles. Mobil 1 15W-50 will also provide better anti-wear protection for higher valve spring tensions in certain racing engines. "
I may be wrong but wasn't the general consensus that we should continue with the same oil (M1 15-50 for most of us) with the addition of a bottle of the "GM Engine Oil Suppliment (EOS)"?
I've ordered six bottles from these guys:
http://www.sdparts.com/
Seems like a reasonable solution to the problem.
Bob is saying Extended is the call, DJ has founded "back by popular demand oil from Mobil 1" what are we thinking here fellas? Is there a consensus.
Best price is here (free shipping if you buy 16qts or more):
http://www.amazon.com/exec/obidos/tg...F7RX4&v=glance
Originally Posted by JPS
Motorcycle oil?
Read the link for the reasons:
Mostly doesn't need to comply with emission controls that are the cause for the reduction of wear protection additives...
Guys, in case I sound like Chicken Little, my decision to stop using Mobill 1 15W50 (or add some additive like GM EOS) was based on chats with Steve Weiner @ Rennsport, Jerry Woods, and other legitimate experts who are all advising a change of oil (or addition of additive). I may try Swepco 306 15W40 which also has alot of support...
