LPMM =
#46
1.5 to 2.0 definitely is different though, I like the 2 more, its deeper and a bit louder.
Cheers,
Mike
#47
I put on 100 Call Dansk Cats and Fister I's (same as LPMM with 2 inch pipes) and the sound is amazing. Very sharp bark at startup, deep raspy idle, and it screams under under acceleration, but no drone and not loud inside when cruising. Highly recommended
#49
^^^ Agree, bcameron59 !
This mod seems to always nearly top the popular mods list , and seems will continue to do so for many years to come !
Thanks for your opinion , I do find it a little contradictory , though it may simply be down to interpretation?
#50
It's not contradictory at all. A 2" ID pipe vs. a 2"OD pipe has an ID difference of maybe 1/16th inch? You won't be able to tell the difference in sound on 1/16th inch. 1/2 inch however is discernible.
#53
Cheers,
Mike
#55
I guess the concern is whether having it large (2" ID) will make it sound as if its blowing (has a hole in it)... and whether it affects any back pressure required by the car otherwise...
#56
The way the system is designed, (opposing bank exhaust terminating at opposite end) , and after traveling through the cats and adj. piping, the diameter difference will actually only do more for sound. It's effect on back pressure is deminished pretty much at the point of the where the muffleres are being modified. I have straight exhaust with the bypass elbows, but the turbos handle all back pressure duties. :-)
