9m 4tech billet heads tested by Total 911 Magazine
#31
I am sorry, I am ignorant on what needs to be done with the ECU... Is it just a matter of having the right "tools" to do the job? With the right hardware addition (i.e. heads, cams etc...) information someone could do a proper re-program??
#33
In order to use a Motronic ECU, you need the tools to "live remap" the engine on a Dyno. These tools are not generally available to anyone except the programmer/tuner that developed them. Without the live remap tools, you cannot adequately reprogram the ECU and ensure maximum performance, drivability, and reliability. We do not have the tools and install MoTeC ECUs which obviously presents a problem with street driven OBDII compliance. Our focus is on Race cars where the MoTeC is designed to operate.
#34
Looking forward to reading all the articles once Colin has the chance to post them
cheers
Craig
#35
If there's no way around it, my next question... as crazy as it is... And Colin, maybe you can chime in here... how much would it cost to ship an engine to the UK for a full mod and tune. Has anyone attempted this before? And, is the OBDII still an issue with that plan? Just doing some brainstorming and research here. Thanks...
#36
Arun,
The issue lies with the OBD2 ecu in the US cars. The bottom line is that it is cannot be remapped without expensive internal modifications, so it usually works out cheaper to replace it with the 1998 993TT OBD2 ecu (which can be remapped with the right equipment) - or simply use a Motec ecu that can easily be remapped.
#37
Arun,
From the sound of things, the Motec ecu is not street legal for some reason? Is that right? Thanks for all the advice and information.
#38
A MoTeC ECU is a stand alone ECU which with proper programming can be made to be rolling road emissions compliant. However, since the ECU is designed primarly to be a racing ECU, it does not (nor does any stand alone ECU) have OBDII coding in it, so the vehicle will fail any OBDII test. The only difference between a Motronic ECU and a MoTeC ECU is the MoTeC has software that allows laptop programming whereas a Motronic does not (outside of 3rd party hackers and OEM manufacturer calibraters). Further, a MoTeC ECU has logging memory which allows a tuner to download information about the sensors whereas Motronic is limited to usually diagnostic equipment via the dealer.
We have done MoTeC ECUs on street cars where OBD II testing is not required ie up through 1995 993s. Some engines without major internal modifications have been emissions tested to be compliant.
#39
Thanks for your patience and all the enlightening information. This OBDII system sounds like a pain in the butt! Now I wish I had a '95 model year! So if I were to get a Motec system installed, when and where is anyone going to check if my car is OBDII compliant?? The dealer during service - which I don't plan on using. Or during emissions testing/state inspection in the required states??
#40
What is OBDII?
My favorite year for 993 is 1995...
#42
OBDII would be used for two things. One would be problem diagnosis and the second would be emissions and/or inspection compliance. In NY, during the annual inspection process the shop is required to plug into the OBDII port to ensure that there are no faults. Any faults and the car will not pass inspection. I'm sure this process varies from state-to-state.
YESSS!!!!
#43
#44
I'm pretty sure they do unless it is specific to the city in TX. In Austin and surrounding areas they plug into the ODBII port and check the relevent stuff. I know because I failed my first attempt because my emmission rediness codes were not reset from my battery being disconnected.
#45
Ahhh GHHOOT IT!! Thank you again for all the explanations. So now, I just need to figure out if my state needs to pull data for emissions/inspections and then never move again! Well I know TX doesn't have any emissions and during the last several yearly inspections, they didn't seem to pull any data from the OBDII port. But I AM moving to MD and I believe they'll be doing all of this... hmphh... Somehow we'll have to crack this code and keep it street drivable. I am telling you guys, I have a felling a lot of folks would be interested in this mod if it were doable!!
YESSS!!!!
YESSS!!!!
