Need to get thin (4-7mm) spacers. Any advice?
I'm getting a little inside edge rubbing up front, so I want to use a thin spacer instead of changing wheels or tires. Do I need to stick with some type of hub-centric spacer (that positively locates the wheel) like this:
http://www.automotion.com/productpage.aspx?pid=102089
There are plenty of flat "shim" type spacers but I worry about the wheel being able to float.
It looks like new studs would be needed too. Is that an easy DIY? Know of any source for longer studs?
And can I just run a spacer on the driver's side?
I've got a pair of 25mm (2.5 cm ~ 1"") hub centric spacers: Porsche OEM part number 993.361.62500 including studs and lug nuts. Send me a pm if you're interested.
Ron
Ron
Eric,
I bought a set of the 996 5mm hub centric spacers to use with my turbo twists. They fit great but you do need longer bolts. I was not comfortable with the number threads I could see on the nut. When I get around to it, I'll install longer studs.
BTW, they are black in color and cost around $80 from the pcar dealer.
George
George
Originally Posted by jayster
I bought mine (3mm) from Rhonda @ FVD
Porsche has 5mm spacers that are somewhat hub=centric (small flanges acting as a supplementary hub). I bought a pair from my local dealer (sorry, no part numbers handy). They are a 993 part number (not a 996 or 986 part number becuase those are sold as well).
By the way, if you use steel nuts (also available from the dealer), you won't need longer studs (according to my dealer and I've had no problems at all).
i would concur on the extended studs with a spacer.
If your steel lug nut doesn't go all the way and has leftover thread left that is simply NOT GOOD and I would never drive like that in a track setting (plus it probably wouldnt' pass tech anyway if the person doing tech is observant)
On my car, there were no extra threads inside the steel nuts. I agree with what you're saying otherwise. Anyhow, I removed my spacers because I don't have a clearance issue with the inside of my rim and my front coil springs anymore. My new suspension has a smaller diameter coil on each corner.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
In looking at a spare hub I have laying around the garage, I measure just shy of 10mm of flange engagement to locate a wheel. You may be fine with up to a plain 5mm spacer. Just thought I would pass that along..
Still plays with cars.
Gert Carnewal has 5 mm spacers and the matching lugs with lock. Porsche OEM.
Thanks for the replies everyone. I'll look into those sources. Any more suggestions are welcome.
