Time limit on harness recall
This may be a really stupid question, but I was wondering if there was a time limit on getting the harness repaired under the recall. Does anyone know? TIA
DFarrow, thanks
I guess I can find my local region's newsletter, locate the dealer ad for its number and call and find out. I can be really lazy without even trying.
I think if you call the dealer with your VIN, they can look it up to see if the recall has been performed. I was just thinking I wouldn't waste my time if the recall time had expired. I plan to call today.
Technical Guru
Originally Posted by dhicks
How do you find out if yours was already done...should the dealer be able to find out or is there a website you can use?
Originally Posted by dfarrow
not sure but it was still in effect for my 96 last summer
I'm the original owner of my 96 and NEVER got anything in the mail about this!!!
I thought this was ONLY for the 95 MY 993
Originally Posted by ceboyd
I thought this was ONLY for the 95 MY 993 ![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
Here's the list of vins that are covered by the harness inspection TSB.
Boost Junkie
if it applies to tts and NB, I assume it applies to NA WBs as well.
In my case, the process was 2 steps. Even though my VIN fell in the range, they had to inspect the car for something first (more than one harness supplier - check for the defective one?) and once that was done and met the criteria, they ordered the harness and called me when it came in to set up an appointment. The first step was done while I waited - less than 30 min.
