993 Forum 1995-1998
Restore - Engine Restorer
Old Sep 13, 2005 | 12:33 AM
jla3317's Avatar
jla3317
Default Restore - Engine Restorer
I tried a search on the 993 board but did not get a hit. Has anyone used something called "Engine Restorer & Lubricant" by Automotive Restore Products? Contains "CSL" formula to "restore" compression, hp and engine life. There is a 6-cylinder version that you add to the engine oil. Advertised in Automobile magazine and on the web at www.RestoreUSA.com. I am interested if it is not a gimmick. Thanks for any input.
Old Sep 13, 2005 | 01:09 AM
Edward's Avatar
Edward
Addicted Specialist
Snake oil. Avoid the additives. The use of a good-quality oil is all you ever need. If you need to rebuild or refresh certain components, then no oil/additive is going to prevent the inevitable.
Edward
Old Sep 13, 2005 | 01:23 AM
kkim's Avatar
kkim
I would tend to agree with Edward on this... but what is it exactly that you are trying to fix?
Old Sep 13, 2005 | 01:50 AM
Mike J's Avatar
Mike J
These additives actually lubricate the cash out of your wallet. I would avoid them since you don't know what they do to the insides of your engine and you certainly do not want to do a rebuild unless you have to.
Old Sep 13, 2005 | 01:53 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
I would refrain from the use of additives such as Engine Restore. Unless of course I find a bottle of liquid 3.8L and RS cams
Old Sep 13, 2005 | 10:13 AM
jla3317's Avatar
jla3317
Thanks for all of your replies! It seemed gimmickey to me. I'm not trying to fix anything per se, just attempting to maintain and prolong. Even though this product is compatible with synthetic oils, you are most likely right that it would not help much except as a placebo! Since I use Mobil 1 and change oil/filter regularly that should be enough.
Old Sep 13, 2005 | 10:46 AM
993Maineiac's Avatar
993Maineiac
Yeah, avoid the additives-but there was also an ad in Automobile for the Turbulator which they say will add up to 35bhp-go for that instead. ;O
Al
Old Sep 13, 2005 | 10:57 AM
joon's Avatar
joon
This Restore product has been out there since at least 1987. I know becasue I used it on my 1979 Chevy Luv pickup truck back then when I was in college. No difference noticed on my already over 100K mile truck. Should have spent the $ on beer instead.
