Engine removal phase 2
DISCONNECT THE BATTERY
Now I’ll spent a few lines about the jacking up!
The 2 front wheels were driven on wooden blocks with a stop to prevent the car from moving forward when lifted. And to be sure that the blocks are not slipping on the floor of my garage, they are equipped with two rods that are introduced in holes drilled through the floor.
The blocks are 9cm height (3.5”) My hyd jack is a AC DK 20 Q…. Ilifted the rear in 2 steps to have it high enough. As you see it on the picture, The lower part of the rear is 85 cm from the ground (33.5”). From what I read on the forum, I think this should be enough to clear the engine. The ATV lift is 9cm high when completely folded. If I put a wooden layer of 3cm (1.2”) this will give me a height of 73cm (28.7”) free to roll the engine on the ATV lift free from the car.
Then I followed the Workshop manual procedure.
Starting with tha AC compressor. 1 electrical connection and 4 bolts (13mm) Here take care to hold the bolt with you hand or it will fall somewhere in the engine bay… I was lucky!
Here you see the bolts and the frame which is under the compressor:
Then the air filter box. 2 clips for the cover. Then 1 screw (10mm) on top of the fix part and an electrical connection (air T°).
When pulling the box out of the manifold, take care not to loose the rubber gasket!
To remove the rear blower, I first removed the left part of it. 2 bolts (10mm)
The rear blower is also hold in place by 2 bolts (10mm)
See picture for their postion:
When it’s removed you have a “nice” view on the electrical compartment on the left wing.
See picture for the connections. There are 3, and each one is connected differently!
The connections on the left side are shown disconnected on the picture. Follow Worshop Manual.
On the right here are the electrical connections:
there are also 3 breather connections on this side:
Then we disconnect the power steering lines….oil spilling! Think about it. Then plug the openings.
Disconnect the fuel line on this side
then the fuel line on the left side
At this stage, I still don't have the throttle cable disconnected. As advised by others, I'll do it when the engine will be a bit lower.
But I miss one step from the workshop manual: page 10-105 n°11 they say "detach breather hose from resonance flap housing"... I do not find it!
So I stop here go for a good night sleep. If you can help me on that one...Thanks
Cheers
![](http://forums.rennlist.com/upload/engine_removal_wheel_blocks.jpg)
![](http://forums.rennlist.com/upload/engine_removal_car_on_jacks.jpg)
![](http://forums.rennlist.com/upload/engine_removal_ac_compressor.jpg)
![](http://forums.rennlist.com/upload/engine_removal_ac_compressor_bolts.jpg)
![](http://forums.rennlist.com/upload/engine_removal_airbox.jpg)
![](http://forums.rennlist.com/upload/engine_removal_rubber_gasket.jpg)
![](http://forums.rennlist.com/upload/engine_removal_rear_blower_bolts.jpg)
![](http://forums.rennlist.com/upload/engine_removal_electrical_compartment.jpg)
![](http://forums.rennlist.com/upload/engine_removal_connections_left_side.jpg)
![](http://forums.rennlist.com/upload/engine_removal_connections_electrical_right_side.jpg)
![](http://forums.rennlist.com/upload/engine_removal_breather_on_right_side.jpg)
![](http://forums.rennlist.com/upload/engine_removal_fuel_and_steering_lines.jpg)
![](http://forums.rennlist.com/upload/engine_removal_fuel_line_left_side.jpg)
Cheers
Is it talking about the clutch breather hose? If so, that is connected to the airbox and you have already removed it.
I'm probably wrong, but I'm not sure what the "resonance flap housing" is in layman's terms.
Originally Posted by kkim
Psst... pass the popcorn, this is getting good. ![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Great Write-up!
I hope this story has a happy ending....and some R rated fun...(for language)..AK
![](https://rennlist.com/forums/images/ranks/veteran_army.png)
I am humbled. A guy disassembles a 993, writes a narrative and takes pictures while he's at it. I am not even sure he has heat in his garage.
Yeah, but he has the nerve to go to sleep in the middle of the story!
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
I say we chip in and set up a webcam at Toga's garage so we can have live reality TV. Better than Fox could ever come up with.
Terry- I agree... and it's his first time to boot. Amazing, eh? Much respect to you, Toga.
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
What a great write up and one that we sorely need. Now Toga go get a Twin Turbo and
do the same thing please! I really do appreciate everyone who does a write up and takes
the time to take pics for the rest of us clown who all somehow originate from the Show-Me state!!
